Question about iRobot Roomba 560 Robotic Vacuum
It is not soakeing the water
Hi I am cleaning a carpet but i can't figure it out how this can soake the water from the carpet please guide me it looks like i am doing something wrong
    President:
  • 2,976 Answers
Unless my information from Roomba is wrong, the unit is for DRY VACUUMING only. It is not made to pick up water.
Posted on Jul 22, 2009
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Why wont my kirby carpet cleaner pick the foam and water off the carpet leaving my carpet soaking wet?
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Jul 26, 2010 | Kirby G6 Bagged Upright Vacuum
Bissell carpet cleaner wont **** water out of carpet.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rw245
Apr 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My machine wont pick up the dirty water. If I take the cover off the recovery tank there is a lot of suction but it wont **** up the water. my carpet is soaked. What can I do
at power head clean out area before power head also look for small hose and clean out and look at rollers,i hope this works if you have directions still they should be able to help you out some more.thanks
Nov 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
128 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
