Question about Dell Computers & Internet
What is the exact mane of the DVI to VGA adapter needed for dell optiplex GX 240?
  • TecHelp Jul 25, 2009
    Thanks for trying to answer.
    I was looking for a (30 + 5 )pins DVI Male to 15 pins VGA female adapter.
    They are pretty expensive I thing that I will get a low end pci graphic card for my system. Again thanks for your input.
  • 42 Answers
Sorry, but what do you mean with mane (can't find a correct translation to dutch)
Do you mean advantage, or do you mean what you can do with it?
Normally a DVI to VGA adapter can be used to connect a display with a VGA connector to a DVI port. If you have 2 ports VGA and DVI, maybe you can connect 2 displays to your pc. It's great working with multiple displays, making your desktop twice the size. For example: you can open your mail program in one display and your web browser in the other.
Posted on Jul 22, 2009
Can i connect my tv thru a dell optiplex745
Does your TV have a VGA port? If not it most likely has an HDMI port. Does your PC have an HDMI out on the video card? If not then you will need a VGA to HDMI adapter, OR a DVI-D to HDMI adapter, depending on if your GPU output is VGA or DVI-D. Then you will need an HDMI cable to go from the TV to the adapter.
Oct 17, 2013 | Dell OPTIPLEX 745 PC Desktop
Windows 7 has been installed in my optiplex gx 240 pc but this is no drivers for sound , lan drivers to fix the problem
Go to the Dell support site on another computer,and look for drivers for you computer model. Download them on a usb drive or on an SD card and install them on you Optiplex computer.
Sep 22, 2013 | NEC Black Nec/dell Optiplex Gx-150/240 Ide...
How to install external monitor to laptop if laptop does not support 15 pin plug from monitor
If your laptop does not have the 15 pin plug (VGA Port) then you will need to get some type of adapter that will make the monitor work. You probably have a DVI monitor.
You just need to make sure you get the correct type of adapter and make sure the ends that plug into the computer are correct such as male or female. For example think of the human male and female body parts when you look at adapters. The vga port on the computer is called a Female port, but the piece that plugs into it is called Male. It's the same with DVI ports.
I think you need a VGA Male to a DVI Female so below is a link to one and for $2.54 from Cable Wholesale.
http://www.cablewholesale.com/specs/dvi-to-vga-cable/30dv-05300.htm
Below is a picture of what it looks like.
Jun 03, 2012 | Dell OptiPlex 780 Desktop Computer 1 x...
What do I need to get so I am able to have an extended desktop?
You will need either a USB to DVI adapter or a dual DVI port graphics card. If you don't hae DVI ports on the monitors, you need VGA adapters.
Feb 08, 2011 | Dell Optiplex 755 Ultra Small Form Factor...
What kind of video card can you use on a Dell Optiplex gx 280 small desktop pc, with 210 watt power supply?
You can use this type of video card PCI Express x16 DVI video card.
Click this link for more information.
Apr 15, 2010 | Dell OptiPlex GX280 PC Desktop
Dell optiplex gx 270 is not giving display
If you are not getting display for your Dell Optiplex GX 270, the issue may be one of three possible causes:
* The VGA cable connection between the Dell PC and the monitor, may not be seated in the VGA port correctly. To resolve this, just make sure the VGA cable is seated completely in the VGA port of the Dell computer and that also the Power cord from the monitor to the power source (i.e wall socket, power strip, surge protector, etc.) is seated securely.
* There may be an issue with the Video card in the Dell PC
* Or there may be an issue with the motherboard for this model of Dell.
To check to determine if the latter is what you are experiencing with this issue, please feel free to review this Dell Support link: Dell Optiplex GX 270 Display issue.
If you have more questions regarding this information, please feel free to reply back to this post.
Regards,
-Mactechtrainer
Feb 19, 2010 | Dell OptiPlex GX270 PC Desktop
I have sound problem in my dell gx 240. all
If using xp then go to the control panel and then into sound and audio devices. there you will see a check box saying place volume icon on taskbar. check this box and click onto apply and it should ow be in the taskbar. hope this helps.
Jan 08, 2010 | Dell OptiPlex GX240 PC Desktop
Monitor compatibility
It will be compatible with the system, just keep on thing in mind, whatever resolution you set your computer at you may have to keep the ratio aspect active so that way the screen looks properly displayed.
Jun 27, 2009 | Dell OptiPlex GX260 PC Desktop
Monitr compatibility
That will plug right in. Your existing monitor has a VGA connection, which matches what you have on this monitor (where it plugs in on the back of the computer you will find a blue connector). Just put this one in it's place.
The industry is moving to DVI, which is a long white connector, but monitors are still coming with the VGA connection anyway. This monitor is DVI capable which means it will be great for your next computer, but you will need to buy the DVI cable separately (not today, but when you eventually get a new computer).
Jun 27, 2009 | Acer Aspire 5100 Notebook
I NEED VGA DRIVER FOR OPTIPLEX GX110, WINDOWS 98
you might be able to get a driver on dells website if not try driver detective at www.drivershq.com
good luck
May 20, 2009 | Dell OPTIPLEX GX 110/200 PIII-733MHz 128MB...
Computers & Internet Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
