I wish to replace all the runners (top, centre and bottom) on left side sliding door on a right hand drive 2005 Fiat Ducato. Does anybody have the detail procedure for the replacement of these parts?
SOURCE: fiat ducato timingbelt problem
on the front engine pulley/harmonic balancer or in a hole on the bellhousing.
SOURCE: Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
SOURCE: My 2005 Town and Country's right sliding door quit
i just fixed one. it had a broken wire in the harness that moves with the slider, you have to completly pull the harness apart to find it
SOURCE: please could you tell me the wiring diagram for a fiat ducato
Check HERE (need register)
Also, its possible that this Reference Guide be interesting.
Hope help with this.
