Is this the one ?
CONTROLS IGN 1
Red (10)
Powertrain Control Module/Cooling Fan Control Module/Automatic Transaxle
The wiring or one of these listed above has a short . Disconnect the cooling fan control module and see if the problem goes away , if it does you need a new cooling fan control module . Do you know where it is ?
Testimonial: "Thank you working on the wiring looking for a short"
will that cause your gas pedal speedometer quit working and then the transmission downshift to lower gear Fuse blows and I change and it's fine for a little bit then blows again
Yes , if it is the PCM shorting inside for some reason.
The PCM controls all of those ! VSS - vehicle speed sensor is a n input to the PCM , which then sends speed info to the instrument cluste vis class 2 serial data bus. Controls shifting , electronic throttle control (gas pedal )
You may need a new PCM
