Question about CB Radios
Cobra 29 xlr
I bought this at a garage sale for my semi.I have never had one of these and have no idea what all the switches are.Is there anywhere i can get a manual for this so i can use it?Please let me know..thanks
  • 1,139 Answers
Re: cobra 29 xlr
Hello peppersdad,
This site should offer help
Posted on Nov 22, 2007
0 characters
3 Points
Cobra 139xlr
I have a 29 xlr?
Sep 09, 2012 | Cobra 29 LTD CB Radio
Cant find vr4 on my cobra 29 made in vietnam
With the covers removed and the front of the radio facing you with the component side up, You will see a transformer with yellow,blue or red colored tape around the center. VR4 is located to the left of that. If you still can't find it, then remove D11 to open up the audio.
Jun 20, 2012 | Cobra 29 LTD CB Radio
Bought a new cb and installed it in a semi truck I recently purchased with twin antennas and doesnt seem to receive or transmit very well
you have to upgrade your antena to higher frequency basicaly a new antina and make sure antina wire does not have a brake in it.
Feb 05, 2011 | Cobra 29 LTD CB Radio
I can occasionally hear people talking on my cobra 29ltd classic but it is hardly ever clear and i dont think they can hear me.any suggestions?
Sounds like you need a tech to "ALIGN" your radio! I have one of the same radios I bought at a yard sale last summer. I just haven't taken it to a tech yet. I have to many radios! lol
Dec 29, 2010 | Cobra 29 LTD CB Radio
Need to locate a power cord for a Cobra 29 xlr.
eBay sells them. They cost more then they are worth but you want your radio working???
Dec 10, 2010 | Cobra 29 LTD CB Radio
I bought a Cobra 29 LTD Classic and i hooked it up no problem and when i turn the speaker up, it cuts out at a certain point, i believe the speaker is gone or blown and i should get an external PA speaker?...
Hi, my name is John. Either that or you have a bad capacitor in the volume. Try going with the external first. Then go from there.May be other issue...Let me know. I will post it here...hope this was helpful rating..
Sep 03, 2010 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
Cobra 29 is one channel off, ch 7 is on ch 6 and so on
The radio needs to be tuned.  This should only be done by a licensed repair shop.  You will spend less money taking it to a shop than you will buying testing and tuning equipment needed to do it yourself, which would void the warranty.
Dec 11, 2008 | Cobra 29 LTD CB Radio
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29
To my knowledge and depending on what board your Cobra 29GTL used, R46 is 47ohms dropping resistor after the switched 12V. Its output is then filtered by C20, 100uF/16V. While it is true that a shorted C20 would burnout R46, the issue is most likely a shorted FET2 (P/N 2SK104H). Should FET2 proved to be shorted, then it is very possible also that inductor/coil near FET2 is defective (LT-A108?).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 15, 2008 | Cobra 29 LTD CB Radio
CB Radios Logo
544 people viewed this question
Top CB Radios Experts
Are you a CB Radio Expert? Answer questions, earn points and help others
