Question about Makita 9924DB Electric Sanders & Polishers
Unable to remove dust bag
I just bought my new 9924DB makita belt sander and I'm having problems removing dust bag.
Just slip a flat screwdriver under one side of the bag clip and lever it off, its just a very tight spring fitting.
Posted on Jan 11, 2012
    Sergeant:
  • 384 Answers
Get your wife to help you remove bag. Turn and pull.
Posted on Jul 22, 2009
  • halfpricesig
    halfpricesig Jan 11, 2012
    just slip a flat screwdriver under one side of the bag clip and lever it off, its just a very tight spring fitting.
Makita Belt Sander 9404 - dust collection bag not collecting the dust. Shooting dust out the front. What can be done to remedy this?
the tool needs cleaned thoroughly. there might be a section of a belt that has jammed the passageway. UNPLUG the tool and turn over to see on the backside if the clog is there, if not I would recommend using safety glasses and compressed air to blow thru the channels to dislodge the material. I havae also used a shop vac to help in this.
Jul 27, 2011 | Makita 9404 4'' x 24'' Belt Sander
I have acquired a makita 9924db belt sander, but not a manual. The dust bag is wide open on the bottom - shouldn't there be some sort of device on it to keep the dust in? Also, I would like to know...
there is usually a plastic clip that slides over the bottom to seal the bag, as for the manual go to "makitausa.com" and you can download a manual from there. Let me know if you need more assistance.
Jul 08, 2011 | Bosch 1274DVS 3" x 21" Belt Sander
Need new power cord for Makita sander. Looks very much like the Makita 9924DB. Where can I get this part? Live in Canada
If you want the Makita cord for this tool it's part number 664026-2. It can be ordered through several online sites like www.ereplacementparts.com for about $22 +shipping. You can also use any 18-2 power cord (18 guage-2 leads) with the molded plug end on it, available at most repair shops and some retailers for about $10. Attaching it to the switch is easy, just mirror the old cord as far as how long each lead should be and how much wire to strip off.
Nov 22, 2010 | Makita 9924DB Electric Sanders & Polishers
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Jun 23, 2010 | Makita 1/4 Sheet Finishing Sander with...
Hello, the dust is not coming out into the bag
if you have compressed air remove the dust bag and blow thru every port and opening you can find. Make sure to wear safety glasses. Then I would run the tool with the dust port facing away from you, there is a buildup inside not allowing proper flow, you should empty the dust bag when half full for maximum performance.
Apr 19, 2010 | Makita 3 x 24" Belt Sander
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Slipping belt
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Jan 18, 2009 | Makita 3 x 24" Belt Sander
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Makita 9924DB Electric Sanders & Polishers Logo
278 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
