Replacement fan motor needed
Maytag Model MEY12F7F-B window A/C with heater (12000BTU). Fan motor overheated and quit. Can't find a suitable replacement motor, part# VDK-050362513-01, 3-speed 220VAC. Fan motor not listed with any of the parts suppliers. Any suggestions?
  • 614 Answers
Google ac repalcement parts or we have a replacement parts site Just schroll down at our web site and you will see replacement parts. Russ
Posted on Jul 22, 2009
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
I have a bad fan/limit control Honeywell L4064A 2188.What would sbe a suitable replacement part number?
take original honeywell model # go to honeywell site and look for original part # and it will give you cross reference #s
Nov 05, 2013 | Honeywell L4064B2236 Fan/Limit Control...
I have a 1995 chrysler cirrus and the heat will not work. Changed the thermastat and still will not work. not sure if the heater core is bad. The hoses are getting hot to the temp they are supposed to but...
Check you fan. If the heater core is still hooked up, you would have to be circulating the hot water through the heater core, then it becomes the issue of the duct route and the fan to help move it through the vent. Fan motor should be easy on this car. Good luck. Make sure you have radiotor fluid in the radiator.
Feb 21, 2011 | 1995 Chrysler Cirrus
1991 Ford tempo gl overheats when in idle and how do I replace power window motor?
Overheating at idle is usually due to the engine cooling fan not working. Could be a bad fan relay (most common cause), bad fan thermostat, or a bad fan motor.
Replacing the power window motor is quite difficult, I would leave this to the pros unless you are really mechanically inclined. I replaced one on an Aerostar, but I don't think I'd try it again.
Sep 23, 2010 | 1991 Ford Tempo 4 Door
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
I have a Goodman Heater model number GMS90904CXA and the fan is making a loud noise. I'd like to replace the fan and motor but don't know model # of the motor and fan???
The motor will have a horsepower and rpm on it. pull it out and take down to a local parts warehouse they will have a replacement
Jan 05, 2009 | Ingram GMS90904CXA Heater
I have a mercury mystique and it is overheating at lower speeds, what is the problem?
Can you verify that the radiator fan is coming on when needed? Your Mystique has an electric radiator fan. A sensor on the engine tells the computer to turn on the fan. If it is overheating in traffic or at speeds lower than 45 mph, you fan is probably not working when it should. Your mechanic should be able to tell with a scan tool if the computer is turning the fan on or not. Most likely culprit is the fan relay, but I've seen these with a bad fan motor also.
Sep 21, 2008 | 1999 Mercury Mystique
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
