Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hi, my machine is cutting knocking off mains trip switch when it's half way through rinse cycle, can you help.
thanks, Mike T
  • mjtnews Nov 21, 2007
    Hi washdoctor, think you misunderstood my problem. The machine is completing the wash cycle and part of rinse, its middle of rinse when knocking off,
    thanks, Mike T
  • 139 Answers
Half wa ythrough the wash the heater is engaging and when it engages the it trips of the mains.. The insulation on the heater has been damaged. Replace the heater its at the front of the drum.. you will have to remove the front panels of the machine and then you will find it on the front of the drum at near the bottom....
Posted on Nov 21, 2007
  • Shaf Ahmed Nov 21, 2007
    Sorry about that... I think now its probably your carbon brushes on your motor.. located on top at the rear of the drum. open up the top of the machine and check to see if their worn...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
WD420 hotpoint door will not open ?
In some cases switching off and back on again solves it. Otherwise try to run Rinse & Spin cycle again, and if after cycle door will stay locked you'll need to check the door lock itself, its wiring and/or main PWB
Please Update me how is it going on this
Mar 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius half load
you can only select half load if you wm has a half load button or switch found on the cosol panel
Feb 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius
What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Apr 10, 2007 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 WM63
some times when there is no motor action people think the machine has stuck try a set of brushes you must diconnect from the electrical mains first if unsure call an expert you can not put a price on safety
Oct 08, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
118 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
