Refrigerators Logo
i
ian raymond Posted on Jan 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Elba rf240b fridge freezer,,,,,freezer cworking fine but fridge no go...have defrosted and cleaned out drain tubes but still no cold in fridge
Electro Med Services
Level 3:
  • Refrigerators Master 6,694 Answers
  • Posted on Jan 24, 2017
Level 3:
Answers
6694
Questions
Helped
1870144
Points
21433
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator".
http://electro-medical.blogspot.com/
I have water in the bottom of my fridge, from what I have read it is because the drain line is clogged. I can't find the drain tube
The water is caused by a blocked drain when the freezer units defrosts. It does this once every 24 hours.
If you pull the fridge out, on the back just below the freezer that is a small black u-bend. That is blocked. Pull it off, soak it in hot water and bleach for 30 minutes. Then flush it through with cold water. Put a little bleach in it and carefully replace it. At the next defrost, the bleach will be diluted and it will clean the pipe down to the compressor pan.
The water comes from the evaporator coils, which are behind the panel at the back of the freezer.
Elba manual
I made a thin flexible steel 'ramrod' to clean drains on fridges ...make sure it is NOT sharpen as it will cut through soft plastic drain
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
You can fix this by yourself and do take care in solving the problem......
1helpful
2answers
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
My freezer is still freezing but the fridge is not cold. You can hear it running but nothing. HELP!
is the fan running in the freezer? if not replace fan .if not unplug fridge,,remove all inside pannels in freezing unit,,in the bac ,in the middle, on the bottom ,there is a drain that drains into the very bottom of fridge,is it like aice bottom across the bottom of the freezer?if so,use hot water to defrost all the ice and may be a hair dryer,water will melt and **** down the drain threw the drain tube,to the bottom of fridge into a shallow pan under the fridge,that slides out(could be messey).clean all bottom of freezer out good(crumbs mostley)that stop up drain and pour water threw drain a few time to clear drain good.reasemble and ur good to go.now if there is no ice and drain is good,you might find ice on coils,this means ur defrost timer is most likeely gone out ,just replace timer
2helpful
Refrigerator and Freezer are not cold enough
sounds like your fridge is iced up.To cheak this you will need to remove rear panel in freezer compartment and cheak if there is ice buld up.If so you may need a defrost timer or your drain tube may be plugged..If those are fine cheak if your defrost thermostat is ok and not split.Hope this helped:)
1helpful
FREezer works fine,frig will not go less than 40 degrees and unit never cuts off
the problem is the freezer drain is plugged up. when the fridge goes into defrost,the water that is suppose to drain out has no where to go. so it refreezes . that ice has plugged up the blend air vents between the freezer & the fridge.
1st put your food in a cooler. Unplug the refridge.
(you may want to take pictures as you go.for the reassembling)
open up the freezer, remove the rear panel, & the bottom panel (if possible)
you will see the coils, underneith the coils you will see an metal tray. it will probly have ice on it.
with a blow dryer, heat the ice till you see the drain . now that drain has to be cleaned out.
that drain runs down to the bottom of refridge into a drain pan. with a wet vac , attach it to the drain tube, until you fell suction in the freezer. small amounts of hot water does help.
( it usually gets plugged up from bugs)
next , open the fridge ,on the ceiling of the fridge.there will be a plastic cover (most models) remove the cover carefully. usually there are 2 passiges from the freezer to the fridge. that is where the cold air drops into the fridge. there will probally be ice in these passages, which has to be removed.(be careful with the stirofoam)
once you have cleaned out all the ice ,reinstall all those pieces.
plug back in the refridge.It will tak a day for it to get cold again.( hint get 2 bags of ice to help speed up the cooling down process)
1helpful
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
1helpful
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
