I have a Whirlpool Duet gas dryer. The electronics and heater all seem to be normal. But, when I start the dryer it will only spin a couple times before it stops as if it is binding. When I push the drum around manually, it feels stiffer than normal. I put it into diagnostic mode and everything worked but when I started it in diagnostic mode it stopped similar to before and displayed a 08 code.
    Problem Solver:
  • 16 Answers
Sounds like something in the blower wheel or a bad motor .....if it makes a wrrrrr sound whn it starts its the motor
Posted on Jul 22, 2009
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
What does F-1 mean on a Duet front load dryer? Our dryer's lights will turn on but, the dryer will not start up. At first we thought the control panel was locked out. But, it wasn't.
The "F-1" error code means a failure occurred with the electronic controls.. This could mean that wires are broken, the electronics shorted out or a manufacturer's default error shut the washer down.
Prevention/Solution: The electronic control panel needs replacement. Find your dryer serial number and search for the part online. This is a lengthy job that usually requires a repairman unless you have dealt with and repaired dryers before.
If your dryer was purchased within the past couple of years, the dryer could be covered under the warranty. Visit the Whirlpool customer service page for more information or Whirlpool-Duet-Dryer-fault-codes
Hope this helps.
Jun 02, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer wont start
hello theres a long pin that sits inside the door make sure it has not snaped off if thats ok then the trouble may be caused by the capacitor next to the motor white cyilnder with couple of wires coming off
regards
shaun
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Burning smell
We had the same problem. After we used it a few times, the smell went away.
Jul 06, 2008 | Whirlpool GGW9250PL Gas Dryer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
