Question about MotorGuide Standard Motor Replacement Parts - Type: Switches And Compone
I am looking for a MotorGuide foot control Part # NP300-09 it may have been replaced with Part # MNP 300-109 ? This is for a Lazer II ES 62# thrust any suggestions Jim
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
  • 3600 Answers
SOURCE: I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL
I need the information off the tag motor frame volts amps and shaft type and I can tell you how to make it work. you didn't leave your e-mail address, also please rate. Thank you.
Posted on Aug 08, 2009
bargainbin2
  • 123 Answers
SOURCE: Only one speed on MotorGuide 300 Stealth 30 lb
The speed control.
Posted on Aug 26, 2009
  • 288 Answers
SOURCE: have a 56lbs thrust motorguide that is 12/24 volt.
2 of the wires are line voltage and they share a common nuetral.if they hook to batteries then the common will go to the neg of each battery and the other leads go to the positive terminal
Posted on Dec 19, 2009
  • 5 Answers
SOURCE: can you change a motorguide 65lb thrust foot
Go to TROLLINGMOTORPARTS.COM AND YOU CAN A WIRING DIAGRAM.
Posted on Apr 30, 2010
I nned a motorguide 46 lb. thrust electric foot controlled trolling motor manual
Go to http://www.boats.net. Let me ask you a question, is it 5 speed? And if so have you lost some or all speeds but 5?. I so, them you need to take the lower unit apart and you will find solder laying in the bottom. You will see that the speed control coil wires at one if the terminals on the brush board has no solder. Clean it up along with the wires so that you see copper and re-solder. This is due to poor quality control on soldering at the manufacturer. When you re-assemble tighten the bolt 45-50 in-lbs only. No more.
Oct 02, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Can you change a motorguide 65lb thrust foot control model with fix speed settings to a variable speed
well a "Speed Controller" can usually be used on ANY DC/AC motor, depending on type, some motors just will not work, with a speed controller... Think of it a bit like a "Light Dimmer", with the "Bulb" being the "Motor"
Have a look below for info. www.stefanv.com/electronics/escprimer.html
Mar 05, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide pro series 46 lb.thrust not turning smooth
Check the beaing locted where the inner shaft passes thru the outer tubing below top of motor
Nov 27, 2008 | MotorGuide Electrical Supplies
MotorGuide Standard Motor Replacement Parts  - Type: Switches And Compone Logo
98 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
ken skalski
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
