Question about Kitchen Ranges
I have a GE XL 44 Gas Stove the oven does not work. It seems I might need to light the pilot . How do I do that ? Where is the pilot for the oven located. Thanks.
    President:
  • Kitchen Ranges Master
  • 1,922 Answers
This is an electronically controlled oven you shouldnt have to manually re-light oven
Posted on Jul 28, 2009
My ge xl44 gas range ..all of a sudden the oven does not work...eveything else does... do i need someone to come out? HELP...
Probably just a weak ignitor. Fairly common on these. If you can change a spark lug you can change an ignitor.. These get weak and dim. if yours comes on but is dim orange it is weak and not allowing the bi-metal to open. If yall bump the stove and the oven comes on that is another sign of a worn out ignitor:
GE XL-44 stove service manual
How it works: Silicone carbide ignition
A tip by TheMobilian
Apr 21, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you light the pilot light of a GE Spectra Stove XL 44? Top burners and broil work fine.
There is no pilot on most modern appliances that use a gas source for ignition. The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface igniters work and the broiler still works, the problem is not a gas related issue or a control board issue. More than likely, you have a weak or failed oven igniter. Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, or no ignition, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The part number for the model you have listed is WB2X9154.
If you have any questions please post back and let me know. I hope this helps you.
Apr 13, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Oct 07, 2009 | GE JGBP28 Gas Kitchen Range
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Oct 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 Gas Oven Bottom Heating
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
343 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
