Question about Sony RM-V310 Remote Control
Problems with hyundai tv
My hyundai tv is only playing sounds but is not showing pictures please help,
nassau Bahamas
  • 6 more comments
  • sally_alyssa Jul 22, 2009
    hi please bear with me yes you had help me with a problem earlier however another problem develop i some how got the Rca polar remote to work with my tv i dont know how yet but when i went to turn of the tv it did not go off and the channels did not work i must have pressed evry button on the remote and in doing so the picture was lost and only sounds are coming in when i press the volume button channels changes and when i press channel it goes blank
    ps i found my old remote do you think that i can reprograme my tv to its origianl state an if so could you tell me how
    i did as you said but it is still showing a grey screen and the audio is still on
    STILL AWAITING YOUR REPLAY
    CHANNELS ARE CHANGING AND NUMBER OF CHANNEL IS SHOWING, NO ANTENNA BUT TV IS HOOKED TO CABLE VIA A WIRE RUNNING FROM THE MAIN CABLE IN THE LIVING ROOM TV IN THE LIVING ROO IS OWN AND IS FUNCTIONING PROPERLY
    CHANNEL UP AND DOWN DOES NOT WORK ON ORIGINAL REMOTE HAVE TO PRESS NUMBER BUT WHEN I DO THE CHAANEL CHANGES
    CHANEL UP AND DOWN ON UNIVERSAL REMOTE ONLY GO TO 11 OR O BUT VOLUME UP AND DOWN MOVES TO OTHER CHANNEL I REALLY THINK IS MESSED UP IN THIS
    PS SHOULD V- CHIP MENU ON ORIGINAL REMOTE - BLOCK BE IN THE OFF POSITION
    SORRY FOR WORKING YOU SO HARD I JUST RELAIZED THAT I HAVE TWO DIFFERENT HYUNDAI TV THE ONE THAT IS GIVING ME THE PROBLEM IS THS HTV 2115 AND ITS REMOTE IS QUITE DIFFERENT I CANNOT FIND THE MANUAL FOR THIS ONE SO I DONOT KNOW WHERE THE INPUT/ SOURCE OF SCAN BUTTON IS LOCATED I WILL TRY TO LOCATE IT AND GET BACK TO YOU ITS 2 AM IN THE MORNING AND I AM VERY TIRED SO TELL ME HAO CAN I REACH YOU LATER ON TODAY
    I AM ABOUT TO SIGN OFF SHOULD I ACCEPT THE SOLUTION SO THAT YOU CAN GET CREDIT OF JUST SIGN OU AND TRY AT A LATER TIME WHEN I CAN LOCATE THE MANUAL?
    YES I GIVE IT A 4 THUMBS UP BUT I STILL NEED T GET THE PROBLEM SOLVE MY ON LINE TECH HAS AGREED TO ASSIT ME FURTHER
    President:
  • 2,777 Answers
It sounds like most likely the video connection is loose on the back of the TV. I helped you earlier actually with your universal remote problem =). Nice to see you again. Check that the video connection (the yellow cable if you are using the yellow white and red) is tight, you can unplug it and plug it back in safely while the TV is on. Try changing the inputs on the TV as well if you can, I know your probably don't have a working remote.
What kind of signal are you trying to watch? TV? A DVD? Satellite?
Thanks
T
Posted on Jul 22, 2009
  • 5 more comments
  • Tim Grayson
    Tim Grayson Jul 22, 2009
    I personally recommend you shut it off, and pull the power plug for a good 2 minutes. You should be able to use the original remote right away, so plug it back in and turn it on using the regular remote.
    I am trying to think what buttons you could have possibly pushed to do that, nothing jumps to mind especially since you still have sound.
    Let me know if the reset works
    T
  • Tim Grayson
    Try hitting the INPUT button or channel buttons on the remote, do you hear it changing channels? Does anything at all display on the screen? A channel number or anything? Do you have an antenna hooked up to this TV, a cable box, cable tv direct out of the wall...?
    T
  • Tim Grayson
    Here is the reply again:
    T
  • Tim Grayson
    When you change the channels, and you see the numbers change, does the sound / audio change along with it? Does it change correctly? Try going down to channels 2 or 3 on the TV, and change the that same channel in the other room, does the audio match? Is there a source / input button on the remote? What about a scan button? Try the source / input button a few times, see if you can get picture, then try the scan button if you have one if that doesnt work.
    Let me know!
    T
  • Tim Grayson
    I believe it should be in the off position yes, not 100% certain on this one. Something is definitely messed up, the original remote should work no matter what, there is no way to disable the original remote, or to change the TV in this regard. Make sure you are on TV mode on the original remote
    T
  • Tim Grayson
    The best thing for you to do is to rate my help on here as 4 thumbs or very helpful. Otherwise I get no credit for the help. If you can email me we can continue working together directly. My email is tim @ timgrayson . net without the spaces. Please rate my help on here so I get the credit for it. I will continue working with you.
    Tim
  • Tim Grayson
    Please accept the solution if you could, and I will get some credit at least. We can work together via email and I can help you find a manual too.
    Tim
My 1992 Chevy Astro Van starts but shuts off. I service it, plugs, distributor cap, wires etc. When I start it it back fires, and cuts off. Lester R. Thurston Nassau, Bahamas
Did it backfire beofre you did the service? I'm guessing you have the wires mixed up.
Firing order 1-6-5-4-3-2, Distributor rotates clockwise
Hope this helps.
Dec 24, 2010 | 1992 Chevrolet Astro Extended
I bought my nokia 5310 in Ft lauderdale and got a number for it but I live in nassau,bahamas and now i need a PUK code to switch my sim card and get a bahamian number. What is the PUK code?
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Aug 22, 2010 | Nokia 5310 Cellular Phone
Carrier 19000btu split, cuts out
Have you replacing main PCB board?
Jul 09, 2009 | Heating & Cooling
Maintenance 1985 freightliner fl112 air brake treadle
there is a cost of $9.99 U.S. DOLLARS.
SEND TO VINCENT HALL
P.O.BOX SS-5506
NASSAU, BAHAMAS
1-242-436-2411.
THANKS
Nov 18, 2008 | 1985 Ford Ranger
LG CU500
try a new battery if that does not work then the USB port may need servicing.
Sep 06, 2008 | LG CU500 Cellular Phone
External Flash for PRO 815 Digital Camera
have the same problem. Nassau Bahamas.
Tried a slave trigger with my old vivitar flash unreliable. got better results with Phoenix D91-BZS from B&H
Jun 18, 2008 | Cameras
Ge easy cam
click on this link and go find your cam model in Pc cams at the bottom
http://www.jascoproducts.com/support/software-downloads.asp#pccams
May 18, 2008 | GE EasyCam Webcam
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Sony RM-V310 Remote Control Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
