Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sudden lost of sound. Remote nor the front pannel
Sudden lost of sound. Remote nor the front pannel will even show the volume control when either are pressed. No volume what so ever.
  • Anonymous Mar 15, 2014
    I use TDA 9370 PS/N2/A/0960 IN AKAEI CTV .THE PROBLEM IS SOME TIME THE FRONT PANNEL KEY NOT FUNCTION PROPERLY.MEN VOLUME SWITCH IS FUNCTION AS CHANNEL UP/DOWN
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Posted on Jul 22, 2009
Mitubishi WD65731 lost sound and I cannot control the volume on the TV or with Remote
check your cables and make sure the vol- button isnt physically stuck
Jul 13, 2015 | Mitsubishi WD65731
I bought AVOL TV at the AAFES last black friday Nov.29 nd i have a problem in the TV theres no picture have sound what will I do.weve been watching and suddenly it went out the picture the sounds is still...
If you still have warranty, use it while you have chance. It seems your tv has an issue with lcd pannel. There is a small chance that one of lcd panel cables disconnected from mainboard. If your lcd pannel has an issue (which is the most expensive part between replacement parts of a tv) i suggest you to buy a new tv instead of replacing tv pannel.
Mar 10, 2014 | Sony RMT-V202 Remote Control
The volume in control pannel is disabled
Go to your system devices on your control panel and enable the sound board. When you click properties, it will show you that it is disable. Just "enable" it there.
Sep 27, 2012 | Acer Veriton 7600G PC Desktop
My Akura TV has suddenly lost most of its volume power, everything else works fine.
i have an akura combi and the sound has just gone off , the remote is going up and down the volume scale but still no sound, please help.
Aug 12, 2012 | Televison & Video
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Apr 09, 2011 | Onkyo TX-910 Receiver
I have an rd 7103. Just moved. Hooked up again and no sound. Reconnected every wire several times and no sound even through the headset. all functions on the remote work even the aux outlet ?????
Mar 21, 2011 | Sherwood RD-7103 Receiver
Lost volume control app for the system tray or start menu
Control Pannel > Sounds and Audio Devices > Check "Place Volume Icon on Taskbar"
Worth a shot.
Apr 13, 2009 | Dell Inspiron E1505 Notebook
My RCA 32" TV
If volume shows erratically behaviour do the following:
  • Take batteries out from remote and check if it is a remote problem.
  • Try pressing and playing volume buttond on TV, see if it can be a button.
  • If it is a button remove front panel and clean button contacts with circuit cleaning solution.
  • If all the above did not work, it is either a faultycontrol panel or a faulty audio pcb on your tv. Them both must betested (control panel it is an easy test if you know how to use amultimeter)
If you need replacement parts enter model here
If you need to call a technician you can ring the number listed on your owner manual
Sep 11, 2008 | Televison & Video
No sound
What exactly is evrything?
Reinstalled sound drivers?
Checked your speaker cord to make sure it comes into the green hole on the back?
made sure your speaker wires are not broken?
Volum on the speakers?
Control pannel> Sound> Speaker Icon: Are the controls HIGHLIGHTED? If not sound driver is not loaded.
Check Volum MUTE. SOme programs MUTE your volume without a warning.
Jan 04, 2008 | Behringer FCA202 - FireWire Audio...
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
