Just bought pioneer sx-1080 receiver need manual to operate it
SOURCE: Pioneer DEH-P3000IB operations manual
How to set the clock on the DEHP3000IB?
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF] (power/source button)
Pres & Hold [Muti-Control] (big button that controls volume) until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segment.
SOURCE: NEED A INSTALATION MANUAL
You can get the manual here:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/280476946DEHP3800MPInstallationManual.pdf
SOURCE: need instruction manual for panasonic bread bakery model sd -bt10p instruction manual
The instruction manuals for Panasonic products are at the Panasonic UK
website. The address where I found the manual for the Panasonic
SD-BT10P is here:
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Just fill in your model number, click enter. Look below the form where
it says "Available Downloads", click View 4.2MB. On the page that
opens, click I accept, on the left, a little way down from the top of
the page, then click on "view" and it will open. You can save the file
by going to the top of the page, click on the second icon from the left
at the top of the page. The one that looks like an old floppy disc. I
would suggest renaming the file so you know what it is, then save it to
wherever you save your files and you're done!
Problems? Email me and I'll attach it to an email for you.
SOURCE: Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
SOURCE: owners Manual for a Pioneer SX-315
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/SX-315%20-HTP-2500--_E
