Question about Yamaha RX-V995 Receiver
My yamaha reciver turns off when the power is turned on
Hey Hey, I wish I can come up with 300 buck to get a new one but times are hard. My yamaha reciver seems to turn off when i push the power button. I looked inside, the fuses are good. no burn marks. There is a clicking sound at the first elec board where the power cord is pluged in. All the wires were disconeccted and reciver tested again, same problem. Which parts would I be able to change and where can I order it. Would it cost more than to replace a new reciver ? Hey, thanks a million --- the system is about 5 years old - used it for about a year. Thanks a million
Roman
techman
  • 3130 Answers
SOURCE: Double clicking sound- no power
The relay contacts are most likely bad in the relay and will most likely happen again. If you know how to solder, take out the relay and look up the numbers on the internet and see what you can find. If not, try to find where the manufactuer is located and call them to see where you can get a new relay. Good Luck
Posted on Mar 28, 2007
SOURCE: Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
Posted on Nov 08, 2007
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
SOURCE: Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Posted on Apr 04, 2010
SOURCE: Yamaha R-700 Natural Sound Stereo Receiver won't turn on.
My stereo receiver aiwa MX-NH2000 can not turn on. It has standby.
Posted on May 06, 2010
Anyone knows what could happen or if there is a chance to be repaired?
Hello, Magda -
Only an authorized Yamaha digital piano (Clarinova) service technician can answer your question regarding a chance of repairing your piano.
If you have not already done so, you can locate an authorized service technician here:
https://www.yamaha.com/paragon/servicerlocator/
Best wishes.
May 03, 2018 | Yamaha Music
Why volume level is to high any time when i turn power of
Make sure the volume is silent when you turn it off. If it still happens get it looked at.
Oct 06, 2014 | Yamaha RX-V375
I have a yamaha stagepas 300 system. When I connected up the mixer to the power cord and switched on white smoke came from the air vent. What is this?
Well, if the system does turns on, it could be just an OPAMP its one of various little 8-pin ic's that are in the pre-amp section that got fried, STAGEPASS YAMAHA Powered mixers runs with a switchmode power supply, if the power amp section has any problem the power supply does not turn on, if you can add further details like if it does turn on, the green light turns on, do you hear something in the speakers, the more the info the best i can help you.
Paul.
Nov 04, 2013 | Yamaha HD-200 / StagePas 300 Package
Hey i have recently bought a yamaha reciver rx-767 and i wierd up my speakers and after about 5 min at a normal volyme the reciver gets verry hot and turns itself off is there a saftey switch you can turn...
remove the speaker wires all together,, and turn the unit on at a high range of volume,, and wait 10 minutes, if it shuts down then, you have a circuit problem that will need to be checked by a shop, if it stays on, turn the unit off, and add one speaker at a time, following the same procedure, that will let you know which output transistor is bad,, when the unit gets feedback , its going to shut down,
Aug 05, 2011 | Audio Players & Recorders
We have just inherited a Yamaha RV-X592 Audio Receiver and have tried all the remote codes listed with the universal remote that we purchased. I have found two listed codes that turn the reciver off, but...
You need a learning remote or a "Logitech Harmony" or a "Universal Remote Control" (Brand name) Yamaha uses "Discrete Power Commands"
You will not find those in any remote under $70 or $80.00
If you don't want to spend the money, program the Yamaha's Remote to control your devices. It will control all features and functions, it will just take some time to program. Hope this helps
Sep 26, 2009 | Yamaha RX-V592 5.1 Channels Receiver
2005 v-star 1100 wont start . starter spins but
i worked for a large yamaha dealer. yes, those bikes are very well known for the starter clutch going out. it's about $85 to $125 in parts and about 1 to 1.5 hours labor. also, an oil filter relocator kit will save you money on servicing or changing your own oil.
Jul 05, 2009 | 2001 Yamaha V Star 1100 Classic
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
Samsung TSK3292F Works for about 2-3 seconds
If you wish to get some details; visit the site linked here. Pull up older posts.
May 13, 2017 | Samsung TSK3292F 32" TV
Powers on but immediately shuts down
No I hate to be the one to give you the bad news but most likly the capacitors in the power supply or the output circuit of this reciver, are bad and most likly need to be overhouled. Or there is mosture contamination on the printed circuit board. It is time to let go and buy a new reciver, unless you want to invest big bucks into the repair of this reciver, as Im sure it can be repaired, but at what cost??
Oct 08, 2006 | Yamaha HTR-5250 Receiver
Yamaha RX-V995 Receiver Logo
322 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
