Question about Home
My Water Keeps Draing
''MY BATH CANT STOP DRAING WATER''
Dear experts,
I have a Aqualux whirlpool and i cant stop the water from draining how can I do it ?
Sincerly
Coustemer
  • snap101
    snap101 May 11, 2010
    is the drain controlled by a lever on the over flow? or does it twist?
  • 123 Answers
The seal for the drain is leaking. It is either the drain itself or the seal beneath the drain. If it is the seal beneath the drain then you will have water going underneath the whirlpool and causing damage; if it is the drain itself simply replace the drain as it's seal is either broken or worn.
Posted on Jul 31, 2009
Gldl500mobb wter not draing from bottem of unit
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 21, 2011 | Maytag Dishwasher
Kenmore series 90 bypassing water. doesn't fill instead water flows out the drain tube once it reaches a level just below small load.
raise the drain hose up till the arch is about level with the back control panel. Once you here the water stop draing restart your machine and it should return to normal operation
Jun 03, 2010 | Kenmore 15864/15862 Top Load Washer
During the spin cycle, my washer seems to spit water out through the draining hose faster than the hose can take take. Water comes out where the draing hose is. How can I stop this?
You have no control ove rthe speed the water comes out of the drain hose, only the ability of the drain to cope with it. You may have a build up of detergent in the drain upstand which has narrowed the paerture of the pipe. Try putting some drain unblocker down the wate pipe into which the hose is, I assume, popped into.
Dec 11, 2009 | Washing Machines
My washer stopped draing the water
The pump may have stopped running, or a hose is pinched or blocked. Check the hose port at the outer tub bottom to see if a stray sock or something is blocking water drain.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water is leaking into the dishwasher when it was not on. The water is really dirty and fills over time. How do I make it stop? It is not on automatic or on at all.
Hi, The water is dirty, do you think it is water draing back into the d/w from the sink? You need to raise the dishwasher drain hose that hooks up to the sink. Make sure the highest point of the drain hose is over the connection where the drain hose hooks to.
If it was fresh water filling the dishwasher, the water would be clean.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Maytag MDB9100A Dishwasher
Hello, how I remove the water from my whirlpool jacuzzi bath Balboa Z112 spa so I can clean it
hook up a garden hose to a faucet. Put the other end in your spa. Then turn on the faucetuntil water comes out the spa end of hose. Make sure the end in the spa is weighted down so it doesn't come out. Then remove the hose from the faucet and keeping it lower than the spa lay the hose where it can drain with causing problems. The water will flow on its own draining the spa. You may want to clean it while its draing so the dirty water will be diluted and drain at thhe same time. Make sure the water is not drained out around any electrical AND!!! NO DIVING!!!! If you lose the prime, just fill the hose again with the faucet. Good luck
Jun 12, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Will not fill with water
Hi, First thing to check is the drain. Make sure your drain hose is higher then the water level and make sure, if you have it draing into a sump that the end of the hose is not laying in the water. I hope this helps. Please let me know,
Thanks
Vic
May 20, 2009 | Kenmore 24032\24036 Top Load Washer
Got a new washer that has button to drain water but its not draing water or doing spin cycle and keeps coming up with error its an indesit wib101 washer it wont finish any cycle at all
check out the DRAIN MOTOR PUMP ,it could be clogged , take it out , inspect it , clean it , and try again , hope this helps AJ
May 13, 2008 | Washing Machines
Washing machine top loading
no codes are on, all lights are continuously on and water is draining out, wash cycle is not strting
Feb 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Home Logo
99 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
