Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
A hamburger caught fire while broiling, I put it out. The stove lists error F10 and will not stop beeping, even as it cools and I press the stop/clear button. This is a Kenmore elite gas range (slide in)
  • 15,935 Answers
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
My frigidaire stove I have to umplugg it because keeps beeping f10 can' stop I push any bottom and keeps beeping
Hi Elizabeth! From what you have posted, your appliance is experiencing a high-temperature error code (F10). A high-temperature error indicates that your oven has reached too high of a temperature for too long of a time period. If unplugging your appliance does not prove to be successful, you would require a visit from a professional to check the temperature sensor and the electronic oven control (brains of your appliance behind the touch pad). If you have any other questions please comment so I can help!
Thanks,
Chris
Dec 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore stove
This is the link to the instructions for troubleshooting the error on your stove. You may need to replace a part.
http://www.applianceblog.com/mainforums/threads/34276-F10-Error-when-using-bake-or-self-cleaning-seems-to-work-fine-when-using-broil
Nov 29, 2013 | managemylife.com
F-10 error code on stove
What Kind Of Stove? The following is for troubleshooting an F-10 error on a Kenmore stove:
After broiling steaks, f10 appeared on screen and constant beeping since. 1-2 hrs now. turned off electricity and keeps beeping.
Press the Stop/Clear button. If that doesn't work, press it and hold for 3 seconds. If you get a fault code, something is broken. If it is associated with broiling, the first thing I would check is the broiler temperature sensor. Is there a buildup of grease on the ceiling of the oven?
Jan 10, 2011 | Kenmore 47783 Electric Single Oven
I have a Kenmore Gas self cleaning stove. I have
Try power cycling the range by turning it off at the breaker. Wait 10 seconds and then reset the breaker. Reset the clock. Sounds like the computer in the range needs to be rebooted. Hope this works.
Jan 11, 2010 | Kenmore Kitchen Ranges
Glass Stovetop
"F1" is an Electronic Oven Control (EOC) Board failure error code. The top stove functions will continue to operate normally, but you probably will not have any bake or broil capabilites as this board controls all your oven functions. This is a very simple repair that you can accomplish yourself, but the price may be something to consider.
Searspartsdirect.com has the part listed under the "Backguard" heading as item number 20 (part #316101001) and lists for $174.
Repairclinic.com has the part listed as item number 496226 and lists for slightly less at $170.
If you do not have a warranty or service plan in place, you, unfortunately, will have to suffer the cost. If you wish to pursue this as a do-it-yourself repair, let me know and I will give you easy step-by-step instructions on how to replace it. I hope this helps you. Let me know if you have further questions.
Jun 06, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
157 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
