My control it doesnt work
2 days ago my remote control stop working, i think its because my lcd is not recognizing the remote control, is there some code or any solution for this??
    Problem Solver:
  • 6 Answers
Try some new battery if that dont work then look on online for the code to reset it
Posted on Jul 22, 2009
Goog day. I have a Samsung LE40A559 LCD TV and about a week ago it stopped responding to the remote. Remote itself is working as when the TV is off and I push buttons on the remote the blue light on TV...
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed.
Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
Nov 05, 2010 | Samsung TV Remote Control
Our remote control has stopped working. We only bought the set 2 weeks ago and used the batteries provided. It stopped working 2 days ago. We have replaced with new batteries and nothing happens. The...
either the remote is bad or on the tv the circuit board at has the remote receiver on it is bad. If you bought it new and it has a warranty contact them for service. If not you could try programming a universal remote to see if it will work your set.
Sep 11, 2010 | Televison & Video
I have a T220 Hd monitor/tv bought 2 years ago. From 2 days the remote control (nearly never used) doesn't work and every 2/3 minutes appares on the screen the menu to select the brightness the colurs...
the batteries of remote control may exhausted , replace it
the remote control working you may check through your mobile camera by following step
1. point the camera in front of your remote control's eye that is the LED
2. now press the remote control's any button and see in the mobile camera that LED is glowing or not
3. you may check other working remote of any other product which you have by this way i.e. through mobile camera
Aug 22, 2010 | Samsung T220HD LCD Monitor
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
Lcd on pixma mp 520 stopped working - was working before.
hi....
take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!.
rate me fixya!!!!
Jun 01, 2009 | Canon PIXMA MP520 InkJet Printer
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Front panel button turn tv on and off
If both the remote and the front panel buttons do not work, I would be thinking that it is a problem with the TV's main uPC area. This type of fault can be involved, and would require factory level service where the fault can be properly analysed.
I can tell you in advance, that this type of fault can be expensive to service.
Jerry G.
Jul 30, 2008 | RCA TruFlat 27F520T 27" TV
2 remotes....same problem
try a firmware upgrade if a firmware upgrade doesnt work, try e-mailing them from www.logitech.com go to contact us and send an e-mail:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Apr 04, 2008 | Logitech Harmony 880 LCD Remote Control
Hay
You can take out the batteries for 20 seconds, then put them back in. Generally if that doesnt work, try to replace the batteries. If that still doesnt work you might have to reset your remote in order to get it functioning again. Let me know if you have done those steps or were you are at after you do this.
Sep 20, 2007 | Universal Remote Control Dish Network...
TV doesn't recognize any remote
The proble is the IR sensor 932220681667 or the small signal board. I would replace the IR sensor first. Also check the firmware and make sure it is BX23U-1.5.0.0_03531 and if it is not go to www.usasupport.com and down load the firware on a USB stick. If the set still has the problem when both are done replace the small signal board.
Jun 17, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
