Question about Rowenta Irons
Rowenta model dm 860 loose power cord
I have a Rowenta Luxe model DM 860. The power intermittently turns on and off when moving the power cable around. Can the power cord be replaced? There are two Torx screws on the bottom but the have a bump in the middle that prevents normal Torx screwdrivers from opening it. Can the power cord be replaced and/or is there an easy way to remove the bottom cover of the iron so I can see what is going on with the power cable? Do I need specialized Torx screwdrivers to get the cover off, and if so any idea where I can buy them?
  • spamoakes Aug 03, 2009
    I was able to get the Torx safety bits on-line for a few bucks...thanks. Now I have the iron open. The power cord doesn't appear to be loose but I do see a bump inside the cord which presumably means the cable is coming apart inside. Any idea where I can buy a replacement power cable? It seems to have some plastic plug-in connectors on the end that I'm not sure if they can be reconnected to a new power cord. Anyway, any idea where I can buy replacement power cords, assuming it can be replaced? Thanks.
  • 43 Answers
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
Posted on Jul 22, 2009
  • VinnyDeath Aug 03, 2009
    Your best bet is to find a local appliance or power tool repair shop. They would have the parts to do it. Since I haven't cracked one of those open, I'm not totally sure how hard it is to work with the connectors, but your options may end up being cutting the cord (while unplugged, of course) at the bump to see what is loose, and if needed getting some wire splices from a local electronics or home improvement store (sometimes called crimps, they're a tubular piece that can be either crimped or soldered to join 2 pieces of wire together), and getting some electrical grade shrink seals to put over the splices (make sure you feed them over the wire before you put the crimps together, as they are tubes you just hit with some heat to shrink and insulate the bare metal connectors and wires) and another larger shrink for the cord.
    Your second option is to take it to a repair shop to have it done professionally. If you aren't totally comfortable with the process, it is probably best to have a professional do it, as you are working with enough electricity to cause serious harm.
    Option 3 is to call Rowenta and ask about replacement parts, such as the cord, and see if you can order it direct from them.
    Hope it helps, and if you have any questions about the process, just ask away.
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
Rowenta DM-880 steam button sticks. Spray button works fine. Any ideas? Thanks.
It is possible that there is dirt that has accumulated into the stem of the steam button and is sticking the button. It is better to remove the lid and make a good cleaning to free the movement. use good spray of jet air, use WD40 to remove dirt and free
This will work for sure.
Aug 21, 2010 | Rowenta Professional DE880 Iron
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
Rowenta DM 273 Iron
It is a Torx tamper proof screw-call 925-827-1011 and order a "Rowenta tool" $10.00 plus shipping this place allso sells Rowenta parts
Jun 13, 2008 | Rowenta Professional DX8800 Iron
Irons Logo
1,120 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
