LCD screen glows super bright then shuts down with red pwr lite
I would appreciate some assistance with My Viewsonic N3250W LCD TV. The LCD screen glows extremely bright. So bright in fact it's hard to see the menus screen. Also, after a minute or so the TV shuts down and the green power light turns red. I've pulled off the back to measure the power supply voltages. With the LCD converter unplugged The PS voltages are fine. No obvious defects on the LCD converter PCB. Is the LCD converter PCB defective?
David
  • 616 Answers
The ps voltages need to checked with inverter plugged in otherwise you can't verify a p/s failure. most likely you will need a new inverter/ps. Julio milleniumtvsvc@gmail.com
Posted on Jul 22, 2009
The Screen is black no video. No respond on Power button. Blue power lite coms on after minut or tow it self and stil no video with blue PWR lite on.
That can be as simple as failed DC filter caps in the power supply, that will be the first thing to check, as you can see in my albums of failed VIEWSONIC and ALL brands of monitors.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 31, 2010 | ViewSonic VX1935wm LCD Monitor
Viewsonic N3250w. Power supply went out and I replaced the bad capacitors. TV worked for a week then now when I turn it on, the screen just turns on and off
Check to see if the 24vdc disappear when the screen black out, it is always there then you have problem in the backlight inverter board. Did you replace the caps in the 24vdc supply also? I replace the whole set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for yo
Sep 05, 2010 | ViewSonic N3250W Television
After relocation to another room, HDTV N3250w wont turn on---
Hi
Thanks for using FixYa. If you are getting power supply to the cord however, there is nothing coming up on the unit then it is the power supply section that is causing this issue. You’ll have to open the back of the unit and then check for any bulged/blown capacitors on the power supply board. Also check for any loose wires inside the unit from the power supply board. All this is only recommended to be done by someone who has electrical expertise and a basic knowledge of internal circuitry of the unit. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | ViewSonic N3251w 32 in. LCD HDTV
Hi, Q7 in the power supply
the pin at one side is the base, et the other side top is colector and bottom emiter, looking the transistor face flat down.
Hector
Apr 01, 2010 | ViewSonic N3250W Television
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
ViewSonic N3250w
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance jah2mil@hotmail.com
Aug 22, 2009 | ViewSonic N3250W Television
ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Solution - just press Menu, Enter and Power buttons at once.
Jan 28, 2008 | ViewSonic N3250W Television
ViewSonic N3250w has black line
Unfortunately, my experience with LCDs says that when you see something like this, it usually indicates that the LCD screen is cracked. If you press gently in the area of deformity and it goes clear then returns to black when you remove pressure, it's a tell-tale sign of a cracked screen. Go to e-bay and see if you can get a replacement screen if you're mechanically up to changing it yourself, else an electronics repair shop might be your only hope.
Dec 08, 2007 | ViewSonic N3250W Television
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
