Question about Home
I cant figure out how to stop water from draining it say open close on it the modle is catherine 60 spacesaver with integral skirt
  • 123 Answers
The seal on the drain is gone bad ot the mechanism is broke. Replace the drain and/or mechanism
Posted on Jul 31, 2009
Where is the access to the drain located on a whhirlpool WFW94HEXW washer
bottom front of the washer behind the panel is the common location of the drain pump and inlet screen.
Sep 27, 2016 | Whirlpool duet Washing Machines
2015 Puma Unleashed 27 SBU. There is a valve under the trailer....it is located under the refrigerator...when I open the valve..it releases water. Should this valve stay open or closed and where is t
Sounds like it may be a low point drain for winterizing. I would disconnect from city water and turn your pump off. Then open the valve. If only a little water comes out then stops have some one watch it while you turn your pump back on. Assuming you have some water in your tank!! If it squirts out under pressure it it probably a drain and should remain closed unless you are winterizing. If it just drips a bit it may be a drain for the defrost function of your refrigerator. After you have figured all that out,hook back up to city water and check it again. Good luck.
Jan 18, 2016 | RVs
Hoover HFI 3015 integrated dishwasher beeping on each program cycle selected
Check out the micro switch on the door seems to not indicate that the machine is properly closed or your outlet pump is blocked and needs to be cleaned out,cause it is clogged up and cant remove water properly
Jan 06, 2014 | Dishwashers
Water Flow to Booster Pump
plastic bag with a few socks in it, can be used to block the skimmer plumbing, if the pump is lower than the pool ! if not it will stop draining after the filter emptys
Apr 25, 2013 | Polaris Pb4 - 60 Booster Pump
The machine stops with 21 minuites remaining the pump is running a clicking noise seems to be coming from the soap dispencer have taken dispencer to bits cant see any stripped teeth any ideas?
See if there is wiggle or play in the tub basket. Open loading door put your hand at the top of basket close to the opening and check movement. There should be no play.If there is water in tub when it stops check the drain hose between tub and drain pump for foreign objects. Let me know.
Jan 11, 2013 | Washing Machines
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
Stopped mid cycle still has water in it cant drain water or get door open or get it to start again ?
you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.once the water is gone then you should be able to open the door.then you need to check the drain hose and the drain pump for any obstructions or some thing stopping the drain pump
Jun 19, 2010 | Washing Machines
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Whirlpool modle ET1CHMXKQO2
if you cant get to the back the only thing left to do is unplug fridge until drain line defrosts
Mar 21, 2007 | Whirlpool ET1FTKXK Top Freezer...
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
