Question about Ricoh Aficio 2022 All-In-One Laser Printer
Please wait is all the display says
Please help me, I work in a busy office and need my copy machine. All it will do is say Please Wait in the display area, no other lights are on. I have tryed turning it off and then back on and even unplugging it. NOthing will work and the copier won't do anything.
Re: Please wait is all the display says
Replace Your Hard Drive. It will fix your problem.
Posted on Nov 29, 2007
0 characters
3 Points
System error "E000"
Reset the device when it does not respond. If the device does not respond, disconnect and then reconnect the power cord. At the device or at the electrical outlet, disconnect the power cord or adapter. Wait approximately ten seconds and then reconnect the power cord. Wait until the device has completed its cycling process before submitting another job request. If this doesn't work try reseting If all else fails I would suggest taking it to a qualified service center. Hope this helps:) Jason
Aug 26, 2007 | Canon PC-D320 Copier
What kind of machine? This type of error would suggest that the machine is not able to complete the self test on startup.
Dec 07, 2014 | Printers & Copiers
Describe 102-372 code problem in m24 xerox work centre
Solution : Power OFF the Printer, Wait 45 Seconds, Then Power ON CAUTION: If the machine is powered OFF / powered ON, all information that is stored in the machine's memory may be erased.
NOTE: Before powering OFF, make sure that all copy or print jobs have completely finished. Never power OFF in the following instances:
  • While data is being received.
  • While jobs are being printed.
  • While jobs are being copied.
  • While a scan is being executed.
  1. Power OFF the machine. The power switch is located on the front right side of the machine under the Control Panel.
    NOTE: Before the machine is powered ON again make sure the Touch Screen is blank.
  2. Power ON the machine.
    NOTE: When the power is ON, a 'Please wait...' message will be displayed. This message indicates that the machine is warming up and cannot be used. After 45 seconds, the machine becomes ready for use.
    If the issue is not resolved repeat steps 1 and 2 a second time.
Mar 07, 2011 | Xerox WorkCentre M-24 Color Copier
We have one in our office but only one function is working now the photocopy and others not working ....How to make it work please? now we have a problem we tried to turn on the power and the message...
First try with this procedure, please press 0, 8 simultaneously while turn on the machine, then the display shows test mode then you have to enter 690 on keypad then press start then you have to press enter key on touch screen . at a time the display shows 'please wait' after few seconds it will show reboot the machine then you have to switch off then turn on the machine. If it is not ready then the firmware has to be updated
May 26, 2010 | Toshiba e-Studio 350 Copier
Long (25 seconds) cleaning wait after each page
You may have a feature on that needs to be turned off or there is somthing that the printer companey needs to fix.
May 01, 2009 | Xerox Phaser 6350DT Laser Printer
Minolta Di 3510f
What do you mean NIX? or do you mean NIC?, please wait message could cause by many issue it could be the temperature issue, machine need to reach a certain level of temp in order for the machine to be ready it could be from you termistor or the fusing lamp might not be working at all
Jul 11, 2008 | Minolta Printers & Copiers
Alarm light flashing, please wait message
Can only try
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Brother MFC-210C stuck in "please wait maintenance"
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
317 people viewed this question
Top Ricoh Printers & Copiers Experts
Bernard D'Souza
Are you a Ricoh Printer and Copier Expert? Answer questions, earn points and help others
