Question about Acer Aspire 5100 Notebook
Acer 5620Z Wireless Adapter Connection Drops
OMG, I had this same problem until today when I ran across this forum. I won my laptop last may in a makeover and had this problem but never got it resolved. I always used a network cable. Today I took your advice and updted the driver. Now I'm wireless. Thank you!!!!!!
Replaced the power board on acer aspire battery will charge to 28% overnight but charge nlight doesnt lightup
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 22, 2012 | Acer Aspire 4720 Notebook
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
Acer aspire battery critically low but not using battery, it shuts off anyhow
Mar 04, 2012 | Acer Aspire 3610 Notebook
My acer netbook batteries will not charge. Any suggestions?
Nov 08, 2011 | Acer Aspire One D255-2670
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
How to install wireless adpter for Acer Extensa 5620z ? every time igot massage that say :( there is no wireless adapter ) thanks
Click Start>Acer>Acer Recovery Management>Restore>Restore Applications and Drivers>Contents.
That will show all the drivers for the computer.
Install the wireless driver.
If your don't have the Acer Recovery Management, download the driver from the Acer website.
Dec 05, 2010 | Computers & Internet
Wireless Adapter/Switch/Connection Issues
Check the setting in "Acer ePM" (Power Management) under "Start" "All Programs" it sounds like the computers put it to sleep.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Acer Wireless Network Card Will Not Connect
Sometimes when you bootup and the error message = "wireless connection has limited or no connection", or has a red X on the wireless icon, it is because the router has not issued an IP address to the wireless card. Right click on the wireless connection and then click Repair.
If this doesn't work then reboot the router then the laptop, this should fix the problem
Sep 02, 2009 | Acer InviLink 802.11b (91.49C10.002)...
Network adapter problem extensa 5620z
you need atheros driver for your laptop, try this link:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=3825&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
Oct 08, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Acer Aspire 5100 Notebook Logo
206 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
