Question about Sharp Office Equipment & Supplies
Firstly power dead that why we change main pwb and then shown E7 (00) and we fixing the sockets after that machine operated and make the copies. quality is good. after two days later we turn on again E7 appeared , L3(00) and after warming up shown H3 (00)..
  • Sharp Master
  • 1,297 Answers
L 3 mirror return trouble.Check the home position sensor.
H 3 high temperature trouble.Clean the ternofuse and termistor in the fusing unit,upper fusing roller.In this case use test command 14 to cancel.
Posted on Aug 01, 2009
Kyocera Mita c610 error
C0610 Bitmap (DIMM) problem
There is a problem with the data or
address bus of the bitmap DRAM.
Defective main
PWB.
Replace the main PWB and check for correct
operation.
DIMM installed
incorrectly.
Check if the DIMM is inserted into the socket
on the main PWB correctly.
Defective DIMM. Replace the DIMM and check for correct
operation.
Dec 15, 2014 | Kyocera Office Equipment & Supplies
How to operate a wheel balancer phoenix pwb 1530
Installation
Remove Wheel Balancer from shipping crate and pallet.
Place Wheel Balancer on flat and stable floor.
Install the Safety hood.
Install threaded rod to spin rod extruding from side of the machine
using the hex bolt.
If Wheel Balancer shakes or moves while spinning the wheel, it needs to be bolted to the ground to ensure proper function.
Electrical plug is preinstalled to fit North American 110 volt electrical socket.
Plug into proper electrical socket. Do not hard wire directly to your electrical source. There is no power surge protection on the machine. Please use a power surge protector to ensure your machine is not damaged.
Install the wheel balancer in a dry and safe environment. Exposure to moisture or extreme heat can damage the components inside the wheel balancer.
VISIT: http://www.nhproequip.com/PDFs/PWB-1530-Operators-Manual1.pdf
May 03, 2014 | Computers & Internet
Erreur C4100
Try plugging machine into a different socket ,preferably on another ring main.then 906 machine.had 3 machines in schools do this,caused by electrical surge corrupting 5volt line to l.s.u.
Mar 19, 2014 | Kyocera Mita TASKalfa 520i Maintenance Kit...
Error C-5102 minolta C450
C5102: Main Motor's failure to turn
Relevant Electrical Parts
Main Motor (M1) Mechanical Control Board (PWB-M)
DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location (Electrical
Component)
Check the M1 connector for proper connection
and correct as necessary.
Check M1 for proper drive coupling and
Check the PWB-M connector for proper
connection and correct as necessary.
M1 operation check PWB-M CNDM1-5 (REM)
PWB-M CNDM1-8 (LOCK)
L-2
5 Change PWB-M - -
6 Change PU1 - -
thanks&regards
Sep 06, 2012 | Minolta Di3510f Bizhub Copier
Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
May 10, 2012 | Xerox WorkCenter 4150 Black and White...
Sharp Printer AR-M205 E1 error
MEASURES AGAINST E1-00 TROUBLE AFTER POWER ON
GENERAL: In very rare cases, E1-00 IMC communication trouble may be experienced when first
powering on the main copier unit
ACTION: To prevent E1-00 trouble when first powering on the copier, the following measures have
been taken:-
1. Resistor R26 (VRS-CZ1JD103J) mounted on the IMC2 PWB has been removed.
2. Capacitor C59 (0.01μF - VCKYCZ1CB103K) mounted on the IMC2 PWB has been
changed to a 1kJ resistor (VRSRCZ1JD102J, Location No. C59).
Note: Even if the part code for the IMC2 PWB is old, the above countermeasures have
been implemented when the mark "?" is applied to the upper right of the last 2
digits of the part code (as shown below):- 209ca36.jpg
Oct 14, 2010 | Sharp AR-M205 Copier
I have a monitor with an Orion PWB-2022 chassis. The picture fades from left to right and also has vertical "jailbars". Changed C418. That was the only electrolytic cap found bad. No change. I have no...
In the CRT tube socket connected to the video board.Resolder that,changes all the caps on the video board around the main IC.That should solved the problems,not than ur main IC in the video board is shorted and dead.
Mar 26, 2010 | Televison & Video
Error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Dec 15, 2008 | Konica Minolta bizhub C250 All-In-One...
Parts
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Jul 31, 2008 | Hitachi 46F500 46" Rear Projection...
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
