Question about Kenmore Washing Machines
Washer washs but does not spin or drain md #116 2222 100 ser # c 212 1146
  • 744 Answers
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
thank u
rate me
Posted on Jul 22, 2009
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
NO SPINNING NOR DRAINING LG TROMM SER.WD-12210DB 10kg
check your pump to make sure that it is clean there is a door on the bottom of the machine open it use the little hose to drain the washer in a bucket then twist the big cap and pull it out clean that trap
Dec 26, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Apr 30, 2008 | Washing Machines
Washing Machines Logo
248 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
