Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Frig is getting colder and colder (below 25 degrees!)
I noticed day before yesterday things on top shelf of refrigerator were a bit frozen on top.....changed setting to be a bit warmer.....didn't help; yesterday things were MORE frozen, so I tested to see if the thing would even turn OFF, which it did....so I turned it back on but at a 3.5 setting (off is zero; coldest is 6)....and it's still getting worse....temperature is down around 24 degrees.....is it done for? Or is there a simple fix?
  • Samsung Master
  • 4,655 Answers
Yor model if the model RS265LABP is very complex. It is very possible that the senser that feels the temperature in the fresh food section is defective. If you would like the manual to put the refrigerator into self diagnostics let me know. The diagnostics test for your model is done at the control panel and will tell you the problem. It will tell you the senser that is not working properly. But an easy fix for most people the test is simple but to go and repair the problem the answer is no easy fix. Sorry for the answer, Sea Breeze
Posted on Jul 22, 2009
Frigidaire frig. model#FGHC2331PF7 is dripping onto top shelf and the filter has ice cycles and what temp should freezer and frig be
If it's brand new and leaking, call the place you bought it from and have them fix it. As for the temp settings; there is a center default in the freezer and you should start there, the fridge also has a default which should be OK. If you need it colder turn it up in small increments and give it a day before you make any additional adjustments. The "cold" in a fridge or freezer also depends on how much stuff you have in the unit, and how often you have the door open.
Sep 08, 2014 | Refrigerators
Frost in top freezer - water leaking in refrigerator - ice maker not working
go through this link it will help you
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Oct 08, 2008 | Frigidaire FRT21HS6D Top Freezer...
Fridge is freezing items on bottom
restrict lower airflow from freezer vents to refrigerator is their a damper air flow control ... try blocking off vent halfway for a day or two next to bottom shelf or drawer how cold is the top shelf of refrigerator refrigerator should never be colder than 37 degrees f"otherwise bad temperature controle or the thermistor
Jan 28, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
Freezer seems to have stopped working on my Model GSS25JFMD.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 31, 2010 | GE 21.9 Cu. Ft. Side-by-Side Refrigerator...
Freezer will not freeze solid. contents are cold, but not frozen. all settings are set to coldest setting. compressor will not kick on when freezer door is left open. I think the problem is that the...
Good day,
No real solution except to put it in a warmer location.
Understand, it is a refrigerator with the freezer just going along for the ride.
All manufacturers state the machine must be in an area that is no colder than 55 degrees.
The problem you have, is once the refrigerator section reaches temperature 34 to 39 degrees, it shuts the whole machine off. If the air temp surrounding the machine is near or approaching that temp, it shuts off, and may be off most of the day,
Domestic refrigerators are engineered to operate in area comfortable to people. Normally 70 to 95 degrees. Below that it will begin to unbalance.
Thank for using FixYa
Jan 12, 2010 | Refrigerators
Refrigerator too warm on coldest setting
The refrigerator coos from the bleed over from the freezer, See if the fan in the freezer is working properly and the crossover duct/vet is not obstructed or close.. Ck to make sure the control in the fridge is working,
Nov 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Top shelf of old sub-zero refigerator 60 degrees, bottom shelf OK
u may have a defrost problem it would be worth paying for the service call if something simple like defrost or a fan would still be more than 200 but worth it
Mar 18, 2009 | Sub-Zero Bottom Freezer Refrigerator
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
125 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
