Question about Whirlpool Dishwashers
Whirlpool quiet Partner 3. is not rinsing the
Whirlpool quiet Partner 3. is not rinsing the soap out of the cup. upper spray arm appears not to be working well. I cleaned all the water deposits out of it and also below the bottom arm under the screen. wonder if I plugged and intake hole or something?
SOURCE: Soap film on dishes
Hard water "filming" is caused primarily by the higher deposit content in hard water clogging up the jets and nozzles. Therefore, there is not the normal pressure for washing or rinsing. This can be eliminated by turning on the dishwasher, while it is empty, and waiting for it to fill and go into it's wash cycle. They open the door and add 3 cups of white vinegar and finish running through the cycle. This will open the nozzles and jets to their full capacity. After that, use a rinse aid for sure.
Posted on Feb 07, 2008
larryyb
  • 291 Answers
SOURCE: soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
Posted on Nov 25, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
  • 423 Answers
SOURCE: Whirpool dishwasher, top tray spray unit does not spin
When the spray arm does not spin and even the powder does get mixed in, your probably have a failing pump/motor.
Before you call for service, try the following. Remove the lower spray arm and filter beneath the spray arm (and as always, check for plugged spray holes and for any broken parts.) Screws will need to be removed to to this.
Rinse everything in the filter, removing anything that does not belong.
With a flash light, inspect the whole sump area, looking for anything that may be blocking water flow. Watch out for broken glass down there!
Look closely at the impeller, looking for damage and that it spins freely and is securely attached.
While you are looking down there, inspect the heating element for damage/being broken/bumpy when it should be smooth.
Reassemble and run a load of those gathering dirty dishes!
The detergent ~should~ dissolve and clean effectively. BUT, if you have recently bought a cheaper, generic dishwasher powder, buy yourself a name brand powder like Electrosol or Cascade and only use it. The cheaper stuff is junk and will rarely clean even in perfectly operating DWs.
If all this does not work, then the pump motor most often the problem and needs to be replaced. When it is being worked on, make sure the heating element is checked. If I were replacing the pump motor, I would also replace heating element at the same time.
Posted on Apr 04, 2009
  • 677 Answers
SOURCE: Whirlpool Gold Dishwasher "Quiet Partner' Fills But Won't Wash
www.dishwasherfilter.com will fix your problem. its your water and not the dishwasher.
Posted on Jul 17, 2009
Whirlpool dishwasher quiet partner lol is not cleaning dishes on top rack
could be a few things clean inside filters and screens listen to it does the wash motor during wash sound strong like it tossing water around in there open the door during the wash see if kicks some water out at you. If it sounds and seems like its working ok then some units have a rubber check valve little flapper in the tube that goes up the back wall to the upper spray arm i have seem break off and clog that tub not allowing any water to the upper spray arm.
Dec 24, 2016 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
The soap latch on my Whirlpool Quiet Partner III won't latch....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 02, 2011 | Whirlpool Dishwashers
How do i remove the upper spray arm on a whirlpool quiet partner III dishwasher. It does not appear to be turning
There is a screw at bottom of arm. Try turning arm before taking screw out. I believe water pressure turns the arm, so if the arm doe not tur while machine is working then you either have a blockage from pump to arm or pump not working properly.
Aug 15, 2010 | Whirlpool Dishwashers
Quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 24, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Upper rinse arm fell off. How does it reattach?
usually it will clip to the basket that holds cups and the like, and engages with the water outlet when the basket is slid into position. Some spray arms have a locking ring that, when the spray bar is held in place, rotates clockwise (if viewed from underneath) and locks the spraybar in place.
Nov 06, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Liquid soap mistakenly used - bubble explosion
Fill the detergent cup with fabric softener for a full cycle. Don't be alarmed if bubbles seep out.
Finish off with a white vinegar wipedown of the insides if it still feels soapy.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool quiet partner 2 is not working!!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
wert
May 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho I do not think the water is spraying from the...
Welcome to fixya,
You said, you have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho you do not think the water is spraying from the arms with adequate force.
I have the same machine.
And I notice if I leave the dishes in the sink rather than rinsing them off and putting them directly into the dishwasher, (Like My Wife says to do). That sometimes I have the same problem.
So I bought Jet Dry, and filled the holder. It's a small sometimes clear plastic knob that unscrews out above the soap dish.Fill it once a month!
Do you put the detergent in both cups or only the closed one?
1. If the load is not real dirty you should only have to fill the one with the door that closes.
If it is real dirty then both. To always use both is a waste of money!
2. If your hot water heater is far from your dishwasher, let the hot water tap run a minute till it comes out hot, before starting the dishwasher.
3.If the dishes or pans are very dirty and or baked on use hi temp scower and heavy or potscruber for those loads.
I use heavy wash and hot temp scower if the stuff is relly messy or dryed on.
And for baked on HI- temp scower and pot scruber which sprays harder.
You will have to experiment a little to see what works for you.
You will find it washeing good after you find what works for your families dish habits!
If you have any more questions let me know!!!
Please remember to leave me a solved before you leave the site.
Thank You for using us!
Huuum
Oct 02, 2008 | Dishwashers
Dishwashers Logo
77 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
