Something got hit on the tv and it is saying no signal and its all fuzzy how do i get the channels to work....help
  • 616 Answers
Might have damaged the rf input check all your cable connections Julio milleniumtvsvc@gmail.com
Posted on Jul 22, 2009
Lost signal
You have changed channels and now it's on the air. If your box is providing a signal on the 3rd or 4th channel you have to get back to those.
Aug 29, 2017 | Televison & Video
My panasonic TX37 lzd 80 tv has on screen message no signal on some freeview channels and the picture is fuzzy
Change your main board but before check if the power supply is ok. Good luck,
Serge.
Feb 26, 2016 | Panasonic Televison & Video
Power comes on - screen says NO SIGNAL. Have already checked cable line with another TV and it works fine. Have we hit something on the remote that has put it into that mode?
The only reason your TV would say "no signal" is that it's searching an input for a signal and not finding it. That being said, Yes, You've probably hit the "input" button on your remote. Easily fixed by selecting a different input or changing the channel on the television.
May 03, 2011 | Televison & Video
"No Signal" on the TV
have you try to reprogram using menu setup/auto channel /before programming in tunner set upcoose cable
after reprogram select channel 3
hope that will helps
regards Alan
May 11, 2010 | Vizio L37 Television
My analog tv does not hold on to the picture. So
you probably need a digital converter box, analog signals were banned like in febuary.
Sep 15, 2009 | Televison & Video
Channel 2 goes fuzzy same time each day
This may be an issue with the broadcast. As all other channels are fine its not the tuner or TV. The broadcasters may be doing work on this channel at the same time every day.
I would advise contacting the people who broadcast TV in your area
Jul 15, 2009 | Televison & Video
Converter Box Problem
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
