Question about RCA R52WH73 Projection Television
I have fl231 problem.
I was just wondering what would happen to if just bypassed the fuse?
Thank you
  • 616 Answers
You might fry the whole board. Julio milleniumtvsvc@gmail.com
Posted on Jul 22, 2009
Rca hd52w59 tv turns on but has a rainbow picture. just happened all of a sudden. what is the problem and about how much would it be to repair?
This sound 's like the very common fl231 fuse problem. First read this artlcle and see if it might help. http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in Then let me know if it might be your problem and how I might help. This generally is not that expensive to repair. Thank you....willtab
Feb 16, 2011 | RCA HD52W59 HDTV Projection Television
Look like a 3d movie
Bad Fuse FL231 will be on deflection board bottom board to the left and are on the right side of FBT flyback transfomer, thier is 3 fuses in a roll but look like small brown rectrangler caps it will be the one in the middle Go to menu then setup if you do not see convergence it is the FUSE!!
Nov 12, 2009 | RCA R52WH73 Projection Television
I replaced the fl231 fuse in my rca HD52W58 and it went back out
Had the same problem , you have to resolder the flyback before replacing the fuse.
Jun 25, 2009 | RCA HD52W58 52" TV
R52WH74 FL231 FUSE
You will need to replace FL231, DL231 and CL230 you can get the parts at the following link with free instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 07, 2009 | Televison & Video
FL231 Fuse Location
the fl231 fuse is a small rectangular fuse tan or brown in color. located on the deflection board next too what is known as a flyback transformer. this is a large black componet with two wires coming from the top. one large red one. it looks sort of like a dristibitor of a car ... too the right there is three small rectagular parts these are fuses the one in the middle is the fuse
Apr 04, 2009 | RCA HD52W59 HDTV Projection Television
Where do you find this fuse?
the fl231 fuse problem can occur with movemtn of tv. Its caused by brittle connections. I get my special fuses from union electronics 1800 648 6657 or google the rca part 259213 check out my article in my tips and tricks section to determine if you have the fl231 problem if you dont have the convergence option in under setup in customer menu. then i would say you do, this is caused by bad solder connections and you wil have to solder this part in.
Oct 05, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Tv help!!!!
ok to replace that board you have to have the entire model number. it will be on the label in small letters it will be likke r52wh77yx1 or ......yx38 or something like that ...this is critical in getting the right part
Sep 09, 2008 | RCA P52937 52" Rear Projection Television
How to remove fuse
solder will have to be removed from component solder side..
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA R52WH73 Projection Television Logo
132 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
