Question about Compaq Computers & Internet
My copaq laptop v 6211 au not starting
When i switch on my laptop, compaq v6211 au, lights are lit for some time , go off , lit again.thats all. nothing happens after that. any solution? It seems it tries loas bios again and again
  • brownleopard
    brownleopard May 11, 2010
    Does the computer go through POST or just black screen all the time?
    Sergeant:
  • 175 Answers
At the bottom of the laptop, find and open the placing of RAM. Unplug each RAM from its bank, clean each RAM and also its bank, Plug them again in different bank. Lock your placing, now check.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread with the results of your work.
Regards;
Hassan
Posted on Jul 22, 2009
Need Drivers for Compaq Presario 6211 AU Laptop
go to the website of compaq presario. click on support. go to get support for your product. go to #1. click on software and drivers downloads. enter product num. Presario 6211AU Notebook. click on the double arrow. select your operating system. then you will see the available software and drivers for your pc.
Apr 06, 2010 | Computers & Internet
Copaq presario cq40 sytem is geatin restrat again and agin when i on loptop is this a bios problem how i can solve it very agent pls
its not BIOS problem, its problem with windows - boot using windows xp cd and repair
in console mode - use CHKDSK - (must be some file corruption)
Feb 07, 2010 | Compaq Presario Notebook
Wlan is disabled on my laptop compaq v6211 laptop.. there is no wireless option in ib network list. i am using xp service pack 3 windows.
have a look for either a physical switch on the case of the laptop or look for a function key on the keyboard.
if you have a key on the keyboard that looks like an aerial of some type then press the function key and this together
Aug 26, 2009 | NetGear WGU624 Router
Compaq Presario V 6211 AU. bluetooth driver is not detecting
Install the driver you received with the bluetooth device to make it work, If you did not receive or lost the disc search the manufacturers site with the product serial/model no.
Jun 23, 2009 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
Blank screen but on/off switch lit up seems locked somehow
Pull the AC cord and the battery out for 20 seconds. Plug it all back in and try again?
Apr 19, 2009 | HP Compaq nx6110 PC Laptop
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Feb 02, 2009 | HP Pavilion dv4000 Notebook
BOOTING PROBLEM
1. Look at the power supply to determine if the fan is working.If not replace the motherboard to see if the computer starts.If the fan is working, try another power supply anyway.
2. Shake the case and listen for loose metallic objects that may cause you computer to stop starting.
3. Inspect the motherboard for broken or burnt components.
4.If you hear beeps when you start your computer try to decode the beep code using the internet.
5.Try a different video card.
6.See if the CPU and memory will work with another motherboard.if yes it means that they are not damaged.
7.Replace the motherboard.If the computer starts it means that your motherboard was damaged.
                                (and)
Unless your machine took a bad fall down some stairs, I am guessing you have a problem with hardware. Unplug the machine and remove the battery. Unplug any external devices like cards, USB devices and printers, etc., and then reboot. Is the hard drive running? Try F10 into setup, and then select LOAD SAFE DEFAULTS AND REBOOT, or something similar. If this does not get it going, check to see if the harddrive or memory has become unseated in their bays somehow. Turn the laptop over, remove the screws covering the little doors, lovingly and gently unscrew the harddrive retaining screw and remove it, and then put it back in and secure the screws. Check to make sure the memory modules are seated correctly, and reseat them if necessary. Then try rebooting. If you get the same problem, go into the BIOS again and check to make sure you are booting to the HDD as first, and then start turning off devices in the BIOS and rebooting in cycles until it boots. Also, try booting to CD (for example, OS installation disk) and if that works, you likely have a boot problem or hardware problem on the hard drive.
Good luck....
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
Does not turn on..!
ur battery may be drained off remove ur battery and switch it to ac power and start again . if its ok insert battery and charge it
Dec 03, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
