I have a brand new mio scooter and the gas cap is stuck. I have had it off 3 times, now I can't get it open. Any suggestions would be great. Thanks
SOURCE: Subaru Impreza gas cap door won't open
If there is one - In trunk - directly behind the gas filler door - behind trunkliner (carpet)
The cable should not have any problems... use a partner to hold the door release and try and pry it open with your fingers.
The spring popper may be bad.
Try this if you dont have an assistant :D
I had this problem with my STI -- easy to fix by bending the little metal on the inside of the fuel door that provides the spring action to open the door. 5 second fix
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question!!
SOURCE: Motor scooter periodically stops
Check the oil level. Be sure it's not low, or high. Also, the auto choke may be stuck.
SOURCE: repairing a sym euro jet x 50cc scooter all aspects
Hello
Is it a GY6 Motor?
Go to www.scootdawg.com this forum should have wat you need also www.scooterrebels.com as well
Best Reguards
Larry
SOURCE: mazda 3 gas cap stuck
Happened to me a few times....Finally this am it broke.... boooo! Reference Service Bulletin SB-01-050/08 when you bring it in hopefully you can get it for free!
Hi keven o'neil, we want to help you with your question, but we
need more information from you. Can you please add details in the comment box?
have you got the user manual maybe it will explain something about the fuel cap you have missed. Hopefully you have not cross threaded the cap when it was screwed on previously.
