Question about Logitech Harmony 550 Remote Control
The # 5 button needs to be pressed hard to respond All the rest are fine. It seems to have worn out.
    Problem Solver:
  • 12 Answers
You have solved your own problem! The # 5 button is worn out and that is quite common in all remotes. (not just the # 5 but any button or buttons)
Posted on Jul 22, 2009
My samsung star s5233W's touch screen not to access the menu . I keep pressing the area where Menu, Phonebook and keypad are (area below) but It doesn't respond. it seems that the screen's calibration is...
You may need to run LCD test press *#0*# on the keypard. Once you have done it go to touch panel sensitivity run the test , if your handest doesnt not have a hardware issue it would work fine , if it does you may need to contact Samsung service cnetre to reset the firmware on your handset
May 04, 2011 | Samsung Star GT-S5233 Cell Phone
My htc touch pro 2 worked fine, now it wont accept my password and now my phone is locked..
A hard reset would be the last option you can do, but unfortunately all your data would be lost,since you cant "log In" to do a backup
these are the steps
press and hold volume down and enter buttons then using your stylus press the reset button until a restore message appears, holding three buttons until a message appear
to hard reset,select hard rest by pressing up volume key.
After that just follow th on screen instruction until done. Your Phone may reboot after this.
Jan 12, 2011 | HTC Cell Phones
TV does note respond to remote. Volume and menu flashes on screen
interference from flourecent lights, maybe the front panel buttons are stuck.
Aug 30, 2009 | Philips 32PFL6704D 32 in. LCD TV
The touch screen does not appear to be working
needs to be replaced , if it does not respond to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now do all data will be lost in factory reset process and if ur touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Mar 05, 2009 | HTC Touch P3450 Smartphone
Sim card missing for htc touch p3450
its a hard ware issue try putting a piece of paper over ur sim card to press it against the pins on the phone sometimes it gets loosen and does not detect sim cards or try restting the device as follows else go for service centre help but try these solutions first
Feb 16, 2009 | HTC Touch P3450 Smartphone
HTC P3400i messaging and hangup problem???????/
try this if it helps
if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
Jan 28, 2009 | HTC Touch P3450 Smartphone
PC does not respond to mouse or keyboard
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 05, 2009 | Computers & Internet
Buttons not responding
Sounds like the button pad has worn out and needs replacement.  Generally the wires are spade lug units which don't come loose.
Nov 15, 2008 | Dishwashers
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Buttons not responding.
you need a new keyboard assembly
Aug 30, 2007 | Motorola Mobility RAZR V3
Logitech Harmony 550 Remote Control Logo
244 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
