Question about Kenwood VR-5900 Receiver
Kenwood vr-5900 no sound
My receiver no decoder for input coaxial or optical, not sound for analog input, no sound for digital input..
My vr 5900 it sounds , but so low you barely can hear it . reygabot@hotmail.com answer me if you can thanks a lot
Posted on Jun 06, 2010
    President:
  • Kenwood Master
  • 1,114 Answers
Check you settings on the receiver. get into the menu of the unit and check the "Audio" settings. if you can choose by specific input, select "Digital" otherwise, select "Auto" that should correct the problem. If you still have a problem, post a comment and I can help you troubleshoot some more.
Posted on Jul 26, 2009
No sound using optical cable connected to LG smart tv 60LN5600
Your receiver has 2 optical inputs. If you plugged in the cable to Input 1, you can select the "CD-R" Input on the receiver. Then use the "Signal Select" button to select Optical 1 (O1).
You can also use the "Input Select" buttons on the remote until the receiver says "Digital". Then use the "Signal Select" button to select Analog (A), Coaxial 1 (C1), Optical 1 (O1), or Optical 2 (O2).
Mar 08, 2015 | Pioneer VSX-820-K Home Theater Receiver
Wenn I connect the coax cable the display show --------, and the Receiver can't detect the digital audio signal, even though I can mesure a PCM signal with the Osilloscope.
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Page 71
There is no sound from digital sources (from COAXIAL or OPTICAL input jack). • Check that the INPUT MODE is not set to "ANALOG" (page 52). • Check that the Analog Direct is not being used. • Check that the "A. ASSIGN" function is not used to reassign the audio input of another source to the selected input (page 53). • Set "ARC" to "ARC OFF" when no sound is output from TV OPTICAL IN jack during TV input (page 58).
Feb 07, 2011 | Sony STRDH510
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) ...
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Jan 07, 2011 | Samsung HTC5500 Theater System
Hi, I have a brand new blu ray player, have set it to bitstream, and am attempting to use an optical audio cable, which does not work. The coax analog works fine but cannot get sound. I see in manual...
Instructions from manual
This receiver is equipped with two DIGITAL IN terminals-one digital coaxial terminal and one digital optical terminal.
You can connect any component to one of the digital terminals using a digital coaxial cable (not supplied) or digital optical cable (not supplied).
IMPORTANT:
• When connecting a video component using the digital terminal, you also need to connect it to the video jack on the rear. Without connecting it to the video jack, you cannot view the playback picture.
• After connecting the components using the DIGITAL IN terminals, correctly set the following if necessary:
- Set the digital input (DIGITAL IN) terminal setting correctly. For details, see "Selecting the Digital Input Terminals-DIGITAL IN" on page 16.
- Select the digital input mode correctly. For details, see "Selecting the Analog or Digital Input Mode" on page 17
The rest can be found on the link below. NOTE the page numbers referrer to the manual pages NOT the pages numbers on the site.
JVC RX 5032VSL Instructions Manual Selecting The Analog Or Digital Input...
Nov 10, 2017 | JVC RX-6030V Receiver
Need help connecting to surround sound to a vizio sound bar
hi,
did u mean connecting the sound bar to ur tv.
u didn't mentioned the model number of ur sound bar.
any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices.
if u are using a satellite receiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input.
ok
Dec 18, 2010 | Emerson LC320EM9 32 in. LCD HDTV
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Adding another device to the system
Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
That would free up the TV analog audio input for other things.
I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
Mar 19, 2010 | RCA RT2760 System
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
Hi i have a yamaha rx-v995 reciver and just percase new pioneer dv-320 dvd. it's output connection is with coaxial conector.when i connect the coaxial to the coaxial onector of my yamaha reciver i dond get...
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
Nov 16, 2009 | Yamaha RX-V995 Receiver
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
Kenwood VR-5900 Receiver Logo
529 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
