SOURCE: my kawasaki vn 750 twin dropped 1 maybe 2 pistons
How much time do you have??? Get a replacement engine. Save yourself the hassle.
SOURCE: need a kawasaki zxi 1100 owners manual
Most of the time you can look up the owners manual on websites as long as you can find the kawasaki website you should be good, i had the same problem with a dirt bitke and i found there website and found the owners manual and downloaded the owners manual and printed it out. Hope i was of some help to you.
SOURCE: 2008 KAWASAKI 600ZZR FUEL PUMP NOT RUNNING.
I doubt that jump starting your machine would have cooked your fuel pump.Does the machine still turn over if not you may have cooked the E.M.U if so the easiest way to check the fuel pump is to unplug it from the loom useing two suitable lengths of wire conect the pump directly to the battery if the the pump emits hum it is working & you will need to check your wireing for possible burns you say the fuses all checked ok I can only assume that you only cheked the fuses by eye in which case it is not allways easy to tell a fuse is blown by visual inspection the only proof positive way is with a multimeter. Another simple test is to bridge the fuse holder first remove the fuse then useing a short piece of wire (no more than fifteen amp you dont want cook the system if there is a fault elsewhere) bare the wire at each end & place it in where the fuse normaly resides turn on the Ignition if the pump comences to function discard offending fuse insert a new one & of you go. hope you are in the wind again soon
SOURCE: vulcan1500 will not start
On The vulcan you can access the starter relay directly, you have 2 bolts for the power leads on the back, carefully short the two big bolts with a screw driver, this wil put power directly on the starter bypassing all. If you think that there is a problem maybee with the starter, then 1st remove the starter from the engine and do the same test outside the engine to avoid damage.
i do have starters in stock. www.bikepartsonline.co.za
