Question about Nikon Coolpix S51c Digital Camera
Nikon coolpix s51 digtal camera memory card says can not be used?
Well my nikon coolpix s51 digtal camera says memory card cant not be used. i bought 10 diffrent cards it still will not work i formated it 2 time card and camera it will not read the card it a sd card if it helps??????
  • 744 Answers
Hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Posted on Jul 22, 2009
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
I have a Nikon Coolpix s51 but my screen is cracked. I am trying to transfer the photos from my memory card and camera to my computer, but i am having trouble figuring out how to do that???
At this point, I would remove the card from the camera. If you don't already have a card reader, invest in one. Connect the card reader to the computer, then plug the card into the reader. You can use Nikon Transfer ( http://support.nikontech.com/app/answers/detail/a_id/61 ) or the operating system's drag&drop to transfer the pictures to your computer.
If you have pictures stored in the camera's internal memory and the screen is at least partially legible, you can try to select "Copy" from the Setup menu to transfer pictures from the internal memory to the memory card before you follow the suggestions in the first paragraph.
Feb 03, 2010 | Nikon COOLPIX S51 Digital Camera
Nikon coolpix s51, lost the adaptor for connection between laptop and camera. where can i get a new one? friend has a nikon coolpix as well. cant understand why his cable doesn't fit.
Nikon usually uses a standard fitting , but there are now 5 or six different "standard" USB tips (see Wikipedi article about USB if you want pictures. GE makes an adapter cable with interchnageable tips. You can also get the replacement cord thru any Nikon dealer (if they are willing to order it for you), But my personal choice is to get a digital media card reader instead and remove the card from the camera and read it thru the card reader- multi format card readers can be bought at office supply stores for under $20 and sometimes OfficeDepot puts their Aptiva brand single format card readers on sale for $5
Aug 24, 2009 | Nikon Cameras
Memory card write protected
Check the side of the memory card. Some of them have a little switch that turns on/off write protection. If there is no switch, you can try to format it in the computer first, then put it in the camera and format it again.
Jul 11, 2009 | Nikon COOLPIX S51 Digital Camera
CANT TRANSFERRENG PICTURES COMPUTER TO CAMERA
The Nikon has software that allows you to transfer/copy photos to the computer.
There is an alternate method of transferring photos.
Get a USB memory card reader, remove the memory card from the camera and insert it into the USB card reader and then plug it into the computer's USB port. Thes computer will see the memory card as an external memory device, You can then copy the photos to your computer.
Jan 17, 2009 | Nikon Coolpix S51c Digital Camera
"memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 13, 2009 | Nikon Coolpix 4500 Digital Camera
Nikon s51 can't transfer video from camera to comptuer
Try removing the memory card and insert it into a USB card reader and connect it to the computer to read/copy the images/video files.
You should format your memory card using the camera functions before you take the next lot of pictures and videos.
Nov 30, 2008 | Nikon COOLPIX L10 Digital Camera
Nikon digital camera malfunction
Hey jackie jean,
If the two year extended warranty you are talking about is a performance service plan purchased at a Best Buy™ store then you could bring the camera into a Geek Squad® precinct in a Best Buy™ store, and they should be able to send it out for service at no charge to you. I am assuming you formatted the memory card in the camera, but if this is not the case and you have formatted the memory card using your computer then I would suggest formatting the memory card in the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Nikon Coolpix S51c Digital Camera
Nikon Coolpix S51 - unable to install software on Window ME
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Dec 06, 2007 | Nikon Coolpix S51c Digital Camera
Nikon Coolpix S51c Digital Camera Logo
226 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
