SOURCE: keyboard broken
Go to a computer surplus place. Look for a box of spare parts with key boards in it for laptops. If you look hard enough you'll find what you need and "cheap".
SOURCE: Nikon Coolpix P4 - no power after little piece between battery and SD card ...
the little white peice is what holds ur battery cover closed i think, so without a closed cover it cant really function. i think so anyway
SOURCE: searching for a clip
Iwould asssume your lookin for number 32 on the door nd latch breakdown, you can call hyour local part distributer for ordering info
#32 8181929 Clip, Trim
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180440.pdf
SOURCE: The latch to my 2000 passat is broken. I guess I
Yep you need to pull forward. The latch on those was made wrong. You shouldn't have to pull it forward to open. Use a light and see if you can find the cable to pull on, with maybe a long nose pliers?
SOURCE: usb input from hard drive to computer is broken
Will replacing the data-cable replace the broken-off piece?
If not, then for about $30, you can buy a new "empty" external case, and then "transplant" your current disk-space into the new case.
Take your current external drive to the computer-store, so that the new case that you buy will be the correct case for your existing disk-drive.
Of course, because you have a "small" (100GB) disk-drive, any warranty for the disk-drive probably has expired, and it would be good "preventative-maintenance" to buy a new external disk-drive, before your current disk-drive unexpectedly "quits" on you.
