Question about Compaq Presario X1000 Notebook
Compaq x1000 i bought 2 i gig memory module.i upgraded the laptop but it seems that there is only one memory this means i can only put one memory or there's another part of the laptop where i can insert the other one? the laptop has 512 mb total....the one i took out is 256 mb....
  • larryd2609 Nov 26, 2007
    i want to up grade my laptop but I only can find 1 Slot to replace the ram. I current have 512 which I was able to locate by turning the laptop over and there is a small screw and plastic tab that says (ram), and I have another 256, but that one I can't find.
The second memory slot is under the keyboard.
Remove two screws at the bottom.
Move downwards 4 switches at the top of the keyboard betwwen these letters (es-f1, f4-f5, f8-f9, f12-del) and raise it from the top.
Be careful not to remove keyboard ribbon-band.
There it is!!!!
Replace memory as standard.
Reverse procedure to set laptop to normal.
Posted on Feb 08, 2008
  • 26 Answers
The original 256 is built into the motherboard. you can only upgrade the machine easily my swapping the other 256 with another chip. I found the engineer guide on the web through some searching, that shows how to assemble the machine and i suppose you could then swap the original ram with a bigger module, but it's not somethign I'd recommend... Why would you need more than 512mb anyway???
Posted on Dec 13, 2007
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
Dec 31, 2010 | Compaq Presario Notebook
I want to upgrade the RAM to 1 gig in my evo 600c what memory should I get that will work? Ive put in a new 50gig hard drive but its really slow
Evo n610c Laptop
Maximun Memory 1024MB Non ECC
Unbuffered CL=2.5. DDR333
DDR PC2700
Number of Slots:
Slot 1 Slot 2
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot
I have the same laptop
Nov 02, 2010 | Compaq Evo N610C Notebook
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
Apr 03, 2010 | Acer Aspire 4315 Notebook
How much ranm can presario x1000 handle
This laptop has 2 x memory slots.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.
1GB, 200-pin SODIMM, DDR PC2700 memory module
Apr 02, 2010 | Compaq Presario X1000 Notebook
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Toshiba sattelite
The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Howdy, help up grading memory
The simplest way to make sure you are buying the correct memory for a machine is to use the memory configurators at or
Jul 25, 2008 | HP Presario V6305NR PC Notebook
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Compaq Presario X1000 Notebook Logo
275 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
