SOURCE: I need a manual for my Hoover F5857-900 steamvac.
I tried hoover.com, none came up for this model.
We're sorry, we were not able to find any models when searching with "f5857-900". Please check the model number, and if you are still not able to find any results, contact our customer service department at 1.330.499.9499.
SOURCE: Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
SOURCE: My hoover F745 900 steamvac brushes will not spin.
If you are handy with a screwdriver undo the casing to access the roller. Once open usually about 4-5 screws you will see that the drivebelt ( rubber band ) has broken. This is the piece you need to replace. Usually most electrical store selling cleaners have these. Take the piece along or get the part number from the manual and replace it yourself. Cheaper than having a tech do it at $90 an hr plus the $5 part
