Question about GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling just had a ge side by side (used) delivered. Refrigeration side not cooling, currently at 47F, been running for about 3 or 4 hours
  • 744 Answers
Hi..
Check the defrost timer,defrost element,and defrost thermostat....
thank u
rate me
Posted on Jul 22, 2009
GE monogram buildin refrigerator - climate control drawer cannot hold the temperature as set for meat. It always shows at 47F.
sounds like the damper door down there is not opening also the fan down may not be coming on to bring temp down to 32.
Sep 17, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Does not freeze
first you must find out if it is a refrigeration fault or an electrical fault. if it is refrigeration - it usually is a gas leak. this will cause the fridge to run and run and not cool anything. if it is electrical. it may run and run and freeze everything - T/stat. not run at all - t/stat fault or short cycle on and off - compressor or relay fault. hope this helps.
koolman77 (refrigeration technician)
Feb 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Top part of the freezer is not working but bottom is and fridge part is not cooling at all???
Sounds like you may have a leak in the refrigeration system, but then it could be ice build up also...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer side went a couple days ago and the frig side went the following day. what causes this or how can i fix it?
If there is no refrigeration effect at all call for service, if there is partial refrigeration remove the grille in the front below the doors and make sure the condenser coil is not fouled with dust, with the refrigerator running the fan in the back should be running as well.
If the coil is full of dust use a vacuum to clean it best you can, if a clogged coil is the culprit cleaning is "some" will provide results.
If the fan in back is not running when the refrigerator is running call for service.
May 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do not...
We need to have a look at the main control board part number WRO2X11838 Tell me if the compressor is running while no cooling or if stopped. Unplug refrigerator and see if the top of compressor is too hot to keep you hand on. My drawing show the control bord in the area of the compressor and inside a box. Let me know if it has burn marks on both sides. Thanks, Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 20, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Brand new GE wont get cold
Sounds like the installers had to remove the doors when the unit was delivered. If they did they might not of hooked the wire harness up at the top of the door hinge or damaged the room thermisters at the top of the door hinge system. Also there is 2 magnetic switches under the top of the doors, you might check the wires on them as well.
Jun 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Why the word ton used for airconditioner.
hi there..
this what i found for you...
The unit ton is used in refrigeration and air conditioning to measure heat absorption. Prior to the introduction of mechanical refrigeration, cooling was accomplished by delivering ice. Installing one ton of refrigeration replaced the daily delivery of one ton of ice.
  • In the United States, a standard ton of refrigeration = 12,000 BTU/h = 200 BTU/min ≈ 3,517 W. It is approximately the power required to cool 1 short ton of water by 1 °F every 10 minutes; or the power required to melt one short ton (2,000 lb) of ice at 0 °C in 24 hours.
  • A ton is also a unit of energy equal to that power for a period of a day, or 24 h × 12,000 BTU/h = 288,000 BTU ≈ 303.9 megajoules.
  • A less common usage is the power required to cool 1 long ton of water by 1 °F every 10 minutes = 13,440 BTU/h ≈ 3,939 W.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 24, 2008 | Heating & Cooling
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
151 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
