Question about Car Audio & Video
Jensen UV9 wont hold preset stations
The radio wont hold the preset stations when vehicle is turned off. On wiring diagram there is no wire listed for the memory.
  • brownleopard
    brownleopard May 11, 2010
    Is the yellow wire connected to an always hot circuit?
  • 4 Answers
The memory wire will be the thick yellow wire that is your constant. you hook the yellow wire to the yellow wire on the radio and you should be good.
Posted on Jul 22, 2009
How do you preset radio stations on a 02 Saturn SL? I have tried tuning to a selected station and holding a preset button for 3-5 seconds and it doesn't work.
If it is aftermarket, some one might not have hook the memory wire up. But most will preset, it will just be lost when you turn off the car. If it is hooked up right, after market or factory, it is an internal failure. Replace the radio.
Nov 22, 2015 | Saturn Cars & Trucks
Will not hold preset stations
One of the wires (often yellow or orange) is a constant voltage source that retains memory with the radio turned off. This wire may not have been connected correctly or maybe not connected at all.
May 04, 2014 | Aiwa CDC-X307
How do you assign preselect numbers to radio stations
You can assign radio station presets on your stock VW radio by tuning to the radio station you would like to preset, and then holding down one of the preset number buttons until the radio beeps. You will now be able to access the station by pressing the preset button.
Oct 15, 2013 | Vehicle Parts & Accessories
Won't remember settings
Your memory wire(12volt constant) and accessory (12volt switched) are in opposite positions. I have seen this happen with aftermarket wiring harnesses for european vehicles (mercedes,audi and VW). Switch the wires.
Aug 13, 2012 | Panasonic CQ-RX100U Car CD/ MP3 Player
I need the color coded wiring diagram for a linear uv9 rear plug
  • If you have any comments feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 15, 2011 | Car Audio & Video
Pioneer deh4000ub radio wont save
Six stations for each band can be stored. 1 Press LIST.
Preset screen is displayed.
2 Use MULTI-CONTROL to store the selected
frequency in memory. Turn to change the preset number. Press and hold to store. You can also store the frequency in memory
by pushing and holding MULTI-CONTROL right.
3 Use MULTI-CONTROL to select the desired
station. Turn to change the station. Press to select.
You can also change the station by pushing MULTI-CONTROL up or down.
To return to the ordinary display, press BAND/ESC or LIST.
Jul 18, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
Cant program car radio
Sorry to say, but you will have to pull the unit and locate the wiring to it. Have a tester for dc voltage and find the power wire that goes on and off with your key. Once that wire has been identified, Find a wire that has 12vdc all the time even with the key off and go to the one that went off and on and cut it. The wire going to the unit strip and splice to 12vdc that is on all the time. Cap and tape the wire you cut that leads away from the unit.
If you need more help feel free to contact me.
Mike
Mar 27, 2009 | Jensen CD3610 IN-DASH CD PLAYER
Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Nov 19, 2008 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Memory/settings non functional
I'm not sure if car radios have internal batteries, but that's what keeps preset memory on home radios. In any case, preset memory requires a small continous electric current, and if there is none coming into the radio then when you switch the car off it will reset. Hope you find something along that line
Mar 15, 2006 | Jensen 200W AM/FM/CD Car Receiver - CD4610
Car Audio & Video Logo
235 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
