Question about Sanyo Televison & Video
Have a sanyo cinema progressive dvd player hooked to tv and put dvd in and it shows just the into to the dvd then will do nothing remote wont control it and tv wont. cant turn dvd player off from remote. what could be worng
SOURCE: insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Posted on Jul 04, 2007
SOURCE: Sanyo dvd player locked
Look at the Fixya posts for the Panasonic DVD RP91.
Posted on Jan 18, 2008
  • 286 Answers
SOURCE: DV 2150 Remote Control Codes
If it's not a well known brand, you're likely not going to find a code for it. I've heard of Go Video, but I don't think it's a very popular brand. (I could be wrong on this point)
Codes don't exist for every tv/dvd/vcr/surround system.
If the remote you bought doesn't have your dvd player listed, then you're probably out of luck.
If it's a very expensive universal remote (like $50-$100) then you might find either a code or a firmware update for it on the manufacturers website.
If not, try every code the instructions list. If you're lucky, one of them will work. If not, c'est la vie.
Posted on Feb 14, 2008
SOURCE: DVD player wont show picture
take the dvd out and hold the stop button on the dvd player for 5 sec (not the remote) the dvd player and that will work
Posted on May 20, 2008
SOURCE: sanyo dvw 7100 is stuck on progressive scan how do I get it off
You may already have the solution, but I ran into this problem too on my 7200. The way to get it out of progressive is press and hold the play button for 5 seconds. Simple - once you know the answer - I was afraid it would involve navigating through menus you couldn't see.
Hope this Helps.
Posted on Apr 16, 2009
I have a Sanyo 19"
I would buy a universal remote control for your tv as some won't operate without the remote control features on it.
Feb 24, 2011 | Sanyo DS19310 19" TV
I have a sanyo cinema progressive dvd player....lost the remote and am trying to program universal...what remote code should I use?
what kind of universal remote do you have???? it can vary sometimes from remote to remote
also, do you have the model of the sanyo system??? some models they make are made by other companies so you would have to use their code.
Aug 04, 2010 | Sanyo Cinematic Progressive Scan DVD...
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
Codes for DVD player
go to codebreakers and look for the code/Hack
Aug 14, 2009 | Broksonic CTVG-5463GVC 19" TV
Sony dvd player
check on the dvd remote if it got this function button and try to deactivate
Oct 30, 2008 | Sony Televison & Video
Pioneer DV 266
To solve "progressive mode" or any other problem on DV-266, just reset all setting to default, as follows;
Using buttons in front panel (not from remote control); - Switch off your DVD Player. - Press & hold STOP button, and press STANDBY/ON (power) button.
Good Luck & enjoy your Pioneer again.....
Apr 23, 2008 | Televison & Video
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
Dec 02, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
190 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
