Question about Onkyo TX-SR705 Receiver
Auto standby mode and cracking and poping sounds
. I have my Playstation 3 connected to my onkyo tx-sr705 and every time i turn it up it goes into standby mode. then i turn it back on and theres like a poping and cracking sound coming from the speakers . can anyone help me find the problem, thank you
  • 9 Answers
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Posted on Aug 14, 2007
simplemitch
  • 752 Answers
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Posted on Sep 15, 2007
  • 4234 Answers
SOURCE: ONKYO TX-DS939 (sound and heat/fan issues)
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Posted on Oct 29, 2008
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
  • 39 Answers
SOURCE: How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Posted on Jun 16, 2009
Onkyo TX NR515 .. when in standby mode .. light is not coming on .. everything works fine .. i must have pressed something by mistake but cant work it out what ... on the display panel in standby mode...
If Zones are turned on or, if a mobile device connected to the Front Input is charging (MHL), the HYBRID STANDBY indicator won't light. See the TX NR515 owner's manual at http://filedepot.onkyousa.com/Files/own_manuals/TX-NR515_English.pdf for more info.
Feb 19, 2015 | Onkyo TX-NR515 AV Receiver
Onkyo standby
I have the same problem. Haven't exactly timed it, but at some point, my TX-SR309 always shuts off by itself when playing music from my iPhone connected in the front USB port. Hopefully someone has a solution for this.
Jan 27, 2014 | Audio Players & Recorders
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
Receiver is on but can't get any sound.
Try initializing the receiver. Although it will erase all your settings and presets . Sometimes this fixes problems. The cpu gets confused. While on hold down the vcr button and press the standby button. The display will read "CLEAR".
Dec 29, 2009 | Onkyo TX-SR705 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
Standby light is on and i can't turn my reciever on or off.
Try to use the control panel switch to turn on. Or maybe your remote battery need a new one.
Jul 26, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
No power
When an amp won't come out of standby mode when you try to turn it on at the receiver, there is usually a problem in the output section (shorted outputs) and the amp may also display something like "protect" on the display if it has one. There could be lots of other causes but outputs are the first thing I'd look at.
If its brand new, then return it for a refund.
Nov 19, 2008 | Onkyo TX-SR705 Receiver
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR705 Receiver Logo
175 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
