Question about Danby DDW497W 22 in. Countertop Dishwasher
I get an E4 error message when I turn on the machine.
I have only owned this dishwasher for less than 6 hours and the first time I turn it on, it gives me an E4 message and beeps loudly, and then the "engine" hums but nothing else happens. Not sure what to do.
  • mrequet Jul 22, 2009
    I never turned it off. I can see the water going into the hose.
    Novelist:
  • 108 Answers
The first thing I would check is to see if you turned the water valve on under the sink.
Posted on Jul 22, 2009
  • 1 more comment
  • StanStihl Jul 22, 2009
    So you turn it on, and no water goes into the dishwasher?
    what brand is it?
    my mistake... I just saw it is a danby... return it.
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
E4 message
take of the btwo black panels at the bottom of the dishwasher and put in a towel to soak up thje excess water this works for me everytime
Jul 31, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Mar 09, 2008 | Dishwashers
Error Message E4 54037380
call manufactor and see if your serial number qualifies for a firmware upgrade.
Dec 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwasher time E4
e4 for most products means it must be reaplaced contacted the company they should be able provide a replacment
Oct 15, 2007 | Kenmore 46123 Stainless Steel Electric...
Danby DDW497W 22 in. Countertop Dishwasher Logo
765 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
