Open following link for wiring diagram with written instructions.
Some of your wiring does not sound up to code.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.htm1) Two differences between regular switch and cooper 277
-Different color screws: Regular switch has two brass screws, and either wire can connect to either screw. Cooper 277 has dark, brass, silver screws, and hot wire connects to dark screw, and wire to light connects to brass screw.
-Cooper needs neutral wire connected to silver screw, to power the indicator light.
2) Some of the wiring in your box does not sound up to code.
Bare ground wire should not be connected to black and white wires.
Electrician should check this out.
Probably the ground wire is being used as a Neutral. Bare ground wires and white neutral wires both connect to neutral busbar at main breaker box.
