Question about PNY GeForce 6200 (VCG6200APB) (128 MB) Graphic Card
I have the NVIDIA 6200 in an IBM tower. Tower was
I have the NVIDIA 6200 in an IBM tower. Tower was given to me, and I saw it work before I took it home. I plugged it into Compaq FS7600 CRT moniter. Computer runs fine, moniter works on other computers, but I get no picture. Any possible troubleshooting advice?
  • historycircu Jul 22, 2009
    The power supply I have running from the wall to the IBM tower is marked for 125v. The cord I have running from the tower to the Compaq moniter is labeled for 125 volts (cord that came with the moniter). The voltage requirements for the NVIDIA 5200 graphics card the moniter is plugged into has a requirement of 1.45v. I checked the specs online and found this:
    Technical Specifications
    Dimensions (H x W) 6.6 x 2.6 (16.76 x 6.6cm)
    Weight 4.2 oz (119 g)
    Bus Type AGP 8X
    Vertical Frequency 60-75 Hz
    Maximum vertical refresh rate 85 Hz
    Display Support Integrated 350-MHz RAMDAC
    Display Maximum Resolution 2048 x 1536 x 32 bpp at 75 Hz
    Display Maximum Resolution (digital port) 1600 x 1200 x 32 bpp with reduced blanking at 60 Hz
    Board Display Options Display Option NVIDIA 128 MB GeForce FX Display Solutions
    Analog CRT or analog flat panel only Slim DB-15 connector
    Analog + TV Slim DB-15 connector + S-video 4-pin mini-DIN connector
    Board Configuration Specification Description
    Chip GeForce FX 5200
    Core clock 240 MHz
    Memory clock 200 MHz
    Frame buffer 128 MB DDR
    Memory I/O 64 bit
    Memory Configuration 4 pcs 16M x 16 DDR
    Connector Slim analog VGA (slim DB-15) with an S-video 4-pin mini-DIN
    Memory type DDR
    Memory amount 128-MB unified frame buffer and texture memory
    Maximum memory 128 MB
    Operating Temperature -13° to 258° F (-25° to +125° C)
    Languages Supported 21
    Certifications BSMI, C-Tick, CE, FCC, Macrovision, UL, VCCI
    Operating systems support Windows 2000 and Windows XP. (Windows 98 and Windows NT 4.0 also supported via Softpaq)
    Voltage 1.45 V
    Core Power 11.3 W
    Image planes 24-bit double buffered
    Z-buffer 32-bit (24-bit with stencil planes)
    Overlay Supported
    Stencil planes 8-bit (maximum)
    Alpha planes 8-bit
    © Copyright 2003 Hewlett-Packard Development Company, L.P.
    Found all that crap here:
    http://h18000.www1.hp.com/products/quick...
    Anyway, I don't think power is the issue. What else could it be? And thanks by the way - that was fast, and I really appreciate it.
    Mike
    Bus Type AGP 8X
    Core clock 240 MHz
    Memory I/O 64 bit
    Memory type DDR
    Voltage 1.45 V
    Core Power 11.3 W
    Overlay Supported
    Alpha planes 8-bit
    Mike
    Genius:
  • 1,043 Answers
Compaq's are notoriously under powered. You should take a look at the power rating on your power supply, then cheque the necessary voltage for the card. Also make sure that the card doesn't have an extra power connection that you need to fill to make it work.
Posted on Jul 22, 2009
  • bvanjoff Jul 22, 2009
    I apologize for not making my comment clearer. The power problem I was commenting on was the power supply inside your PC. Most of the manufacturers under power their CPU's. They often put power supplies that barely cover the unit that comes out of factory. Once the owner starts swapping out the parts inside they start having issues because of the power. The only other troubleshooting steps that come to mind for the 6200 is the output connector's. There was a problem with some of the PNY 6200's having one or the other connectors dying out. I'm not sure what you saw the tower connected to originally but if you have access to another CRT I would try it out. Some of the connectors had cold solder joints on them. If your local PC repair shop has a tester for the CRT connector it would be worth a check. If it is the connector have a look at the solder joints. Hopefully that will solve the issue.
Lg ibm multinet i tower allows power to the motherboard but wont start up, what should i do?
Do you have the original set up disk? Or an emergency disk? If so try them. There is a danger you may lose all your files and software, so don't re---install from scratch. MS Windows disk has a 'Repair' option
Apr 18, 2014 | Computers & Internet
remove the power cord, remove the bios battery, short the two contact together in the battery holder for a few seconds, replace the battery and power cord and try again.
if that doesn't work, start removing items/plugs (not the big 20/24 pin one) from the motherboard until you get beeping noises.
if still nothing then put everything back and try a different power supply.
if that doesn't work, your motherboard is probably dead.
Our IBM X3200M3 Tower server is unstable - any suggestions please?
Perhaps one of the case feet broke off - try slipping a small thin piece of wood under one corner of the case. If that works, super-glue it in place.
Mar 29, 2011 | IBM System x3200 M3 7328 Server tower ...
Which is better, the NVIDIA GeForce4 MX Integrated GPU or the NVIDIA GeForce 6200?
The 6200 has dedicated memory and being a several years more recent design is easily the better of the two.
Oct 04, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Hard drive says it is a n IBM Deskstar, the outside of the tower says Netvista, where do i look and to find out what is really in this thing and where can I download for free a user guide /manual.
you can get the system snapshot. you can use any external tool like pc wizard 2008 to get a complete configuration of your system.
if you donot want to use any external tool then there is an option in windows also.
just go to start->run-> msinfo32.exe
from this tool also you can get the system configuration completely at very high level.
Apr 21, 2009 | Computers & Internet
Nvidia 6200 agp will not play games on s video
What Monitor settings are u using? Try higher frequency & if its a 17" monitor use 1024 x768 setting(resolution) and frequency 75-80 Hz. Also check the nVidia website for driver update for this model. I recently saw that there is a new driver in this category!!!!........sodeep
Mar 24, 2009 | Nvidia GeForce 6200 AGP Graphic Card
NetVista M42 8305 mobo jumpers & pins settings
GET ALARGE TOWER CASE TO FIT IT CONVINIENTLY
Aug 27, 2007 | IBM NetVista M42 PC Desktop
The tower of the washing machine isnt spining, but the base of the tower is.
The "tower" that you are referring to I assume is the agitator. If your agitator isn't moving, the agitator dogs (or teeth you mentioned) are the general suspect. They are made of plastic and typically wear out. The heavier the use, the quicker they wear out. If the teeth on the inside wall of the agitator are still in good shape, the dogs can be replaced without replacing the entire agitator and can be purchased at most appliance parts stores for less than $10. I hope this helps.
Apr 11, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
PNY GeForce 6200 (VCG6200APB) (128 MB) Graphic Card Logo
364 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
