Scanning speed slows down after approx 100 pages. Is it possible to talk to a 1220 expert on phone to describe multipule problems, today?
  • 490 Answers
Scanner 'slows' down depending upon various conditions. For color images and large detailed files, there may be some slowing down. The most common cause is insufficent disk space. Check where you are directing the computer to write the scanned images. Have sufficient space and do a 'defrag' done.
S. Mohan, India.
Posted on Jul 23, 2009
2007 HONDA ACCORD SECOND GEAR SHUDDER
Well, you did a really good job of describing the symptoms, but you didn't do so well describing the car. Are we talking about an automatic or standard transmission? are we talking about a four or six cylinder engine? You are asking about a drivetrain problem without giving any information about what drivetrain the vehicle is equipped with.
With all that said, IF we are talking about an automatic transmission being pushed by a V-6 engine, then there is a Technical Service Bulletin (TSB) that matches the symptoms you are describing. In this case, the problem is most likely being caused by a deformed or damaged exhaust pipe "A" mounting bracket.
Inspect the rubber bracket for cracks or torn rubber. If the bracket is damaged replace the bracket. Bend the stud on the exhaust pipe if necessary to get the stud to go through the bracket as straight as possible so the stud does not "ground" against the sides of the bracket. (see diagram)
May 22, 2012 | Honda Accord Cars & Trucks
Describe your Satellite L505DGS6000 Laptop AMD Turion II dualcore M500 160" HD LCD 4GB DDR2 320 (PSLV6U01F009) PC Notebook Problem . Computer would not boot up windows. Found that HD had failed....
if boot up but slow, you have tot test memory amount and speed and temperature of cpu cooler. if your hard drive is not have 100% smart feature test result, may be slow down. it is rarely with power problem. but you can test with another AC Adapter.
Oct 04, 2017 | Toshiba Satellite L505DGS6000 Notebook
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
Jul 04, 2011 | Canon DR-9080C Path-Through Scanner
Canon LiDE 110 scanner. Just bought, connected to my MacBook-even with the lowest resolution (75 dpi) & simple b/w document setting, I'm getting only 2 pages per minute! There are no files or...
There are two possibilities for the scanner output being slow. a) Lack of contiguous space in the hard disk- Do a defrag or release space by deleting unwanted space and run scandisk; b) Uninstall the current driver and reinstall proper device driver matching the Operating System you are using.
S. Mohan, Chennai, India.
Apr 23, 2011 | Canon DR-9080C Path-Through Scanner
My canon dr-3080 cii is running at a low speed. it was at its maximum and suddenly slowed down. rebooted cpu and switched scanner on /off and chcked settings with no results. please help
Scanner will continue to scan at the same Speed! The problem is in the computer. Check if you have enough disk space, do a 'defrag' on your harddisk, create extra space by deleting unwanted files. IF your processor is slow and if you are scanning in color or converting to PDF while scanning, it may slow down the output.
Dec 22, 2010 | Canon DR-3080CII Path-Through Flatbed...
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
Scanning speed slowed...
did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
Jun 27, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
343 people viewed this question
k24674
jasbo
jasbo
