Sony KP-65WS500: Shuts off when hot?
Hello friends,
I am having an issue with my ancient Sony projection tv. It turns on fine but will shut off when the TV heats up from a few minutes of watch. I had a similar problem with a Toshiba which was solved by replacing the bulb. I was wondering if the same remedy can be applied here. Please let me know if you know of any bulb replacement place online for me to purchase from, part number, and or perhaps another alternative as to how to resolve this issue.
Thanks,
-Friend
  • 616 Answers
There is no "bulb" in your tv , you have a CRT projection tv, need to have power supply checked as well as the convergence board. Have a trained tech do it, this is not for beginners. Julio milleniumtvsvc@gmail.com
Posted on Jul 22, 2009
Tv comes on then turns itself off
Sounds like the projection bulb is heating up then it shuts off for safety reasons. If you can locate the bulb, there is most likely a screen (wire mesh) that traps dust when the fan is on to cool the bulb. Try cleaning this screen and see if it helps. It could be already too late and you might have to replace the bulb.
Feb 27, 2014 | Sony KP-65WS500 65" Rear Projection...
Sony KP-65WS500 TV shuts off by it self....after I turn it back on, a minute later it goes off again.
The 8 blinks means its a High Voltage error which mean ur D- board is bad it'll be T8005.
Mar 27, 2011 | Sony KP-65WS500 65" Rear Projection...
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
My sony KP-65WS500 turns on to blue screen then black with only sound, then shuts off? They just replaced are cable box a few days ago. We unhooked everything and tried to play a dvd....same thing happens?...
It seems that you have an issue with your Video Board, but you say that when the screen turns black, it shuts off. The lamp is not going to be the issue here, since it only produces a white light, regarding the image cutting off, it could be the ballast, but before this, you should've notice a dimmer image. For what most probably the power supply might be having a glitch. Definitely I recommend to contact a Tech so they can analyze the symptoms on the TV and diagnose the issue.
Oct 18, 2009 | Sony Televison & Video
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
I am getting 5 blinks
If the whole screen turns a bright blue and shuts down then you may have a bad blue crt. This will need to be replaced plus adjustments/alignments. Get an authorized Sony servicer to do the repair. Good Luck
Jan 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
