Model LN32A330JDXZA. Ver-cj03
SOURCE: no colour when dvd player connected to tv
I would try a different set of cables to hook up the dvd player, sounds like you either have bad wires or bad ports on either the tv or dvd player. Test each and see which one it is, hopefully it's only a set of cables.
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you: http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HP-R4262&dType=D&mType=UM&vType=R&prd_ia_cd=&acc_ia_fl=&disp_nm=HP-R4262
SOURCE: Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
SOURCE: loud pop sound, still have sound, image is still
you have a blown cap in your lg's power board the electoletic cap looks like a can and the bad one will have a domed top where it vented the value is written on the side you can replace them or have it done and you should be good to go
