Question about EliteGroup KN1 Lite Extreme Motherboard
Need help with connections
Where do i connect my audio connector from my cdrom to the motherboard? audio in has a jumper jack and cdin has a funny looking jumper jack with a funny looking bulb on it.
  • 72 Answers
There's at least one connector that matches the one coming from the CD drive - analog (3 or 4 pins) or digital (an integrated connector). If you have the book for your motherboard, look in the pin diagram.
Posted on Jul 22, 2009
Connecting cdrom &dvdrom to A8M2N-LA m/b?
You may have to use the front Line Input connector F_LINE_IN1 in the corner. There doesn't appear to be a dedicated DVD audio input listed on the internal connector listing in the manual:-
http://h10010.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&dlc=en&docname=c00714578
Feb 26, 2014 | HP Nodus3 Motherboard Asus A8m2n-la 45...
I want to know where the connection points are on the motherboard for the front mic and audio jacks. I have a epox ep-5pdaj motherboard. Will you send me a diagram please.
close to the back panel of the mainboard, below the back i/o connectors and 3.5mm audio jacks.
You need to remove the two jumpers from the pins, this is where you connect the front panel audio connector, if your case has each wire separate. then please look at this webpage http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm look at the part "For AC97 Front Panel Audio" PIN 1 should read MIC. If not, then scroll down, you are reading the wrong part of the page.
Aug 07, 2010 | EPoX EP-5PDAJ Motherboard
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
http://www.asus.com/Search.aspx?SearchKey=P5S800-VM
You'll need to download and install Adobe reader to view the manual;
http://www.adobe.com/products/reader/
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
http://www.cablestogo.com/product.asp?cat_id=2009&sku=40422
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Cheers'
Mike
Mar 08, 2010 | Computers & Internet
I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
Oct 04, 2009 | Computers & Internet
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
Connect audio jack to motherboard
Is this a Gigabyte motherboard?
If so you can go to the Gigabyte WEB site and download the manual and or diagram of the motherboard that shows the various connectors on the motherboard.
Jul 22, 2009 | Intel Motherboard
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Connection Antec Case Audio Connectors to SY-K7VME Motherboard
AC'97 IS YOUR SOUND/AUDIO. THE HDA IS HIGH DEFINITION AUDIO. RICHARDM69
Dec 05, 2008 | Soyo Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Viper MSNV-939 ATX Socket 939 audio connector jumper settings
 u short the pins with jumpers as per the diag
        5    4     3    2    1
       10          8     7    6
in this u short the   5,10  with one jumper &   3,8 wth another jumper
was this helpful to u, give the rating for me
thanks
Oct 15, 2007 | Mach Speed (S755) Motherboard
EliteGroup KN1 Lite Extreme  Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
